after engine start up sound???
Old Jan 15, 2003 | 03:21 PM
masterjoe's Avatar
hello was wondering if anyone can give me a answer to this sound problem?
i have a 99 max sel with 65,000 mile on it and when i started the engine it started up good and as soon as it started the engine it made a whirling cranking sound like a motor spining the sound came from the front near engine but cant pin point it does anyone have similar problem?/ or know what it could be ???
Old Jan 15, 2003 | 05:02 PM
Victim64's Avatar
Re: after engine start up sound???
If this is the sound I am thinking of it is the starter. Means it needs to have a few parts lubricated.
Old Jan 15, 2003 | 05:35 PM
Jamsan's Avatar
Have the same problem, and I'm guessing it only happens when its cold out...There is a good read and guide on how to re-grease your starter at www.motorvate.ca ....should take a look, very helpful site.
Old Jan 15, 2003 | 06:32 PM
qnpark's Avatar
I had the same problem its your starter dont worrie its nothing major just get it cleaned and lubbed up.
Old Jan 15, 2003 | 10:53 PM
sebaxx's Avatar
maybe
Dont worry theres two things, maybe is the starter or maybe is the oil sensors of the engine, when the weather is very coold the sensors trying to get oil to the engine(upper side) and thats the sound that you hear....but is normal, after the engine is warm, the sound fo off
Old Jan 16, 2003 | 04:38 AM
Juki5536's Avatar
Yeah me and my dad have the same problem. His is a little more frequent, (the whirling sound when you start it up) but it only happens when it's cold. I don't worry about it that much, maybe ill check out the starter an stuff. Also, is 4 quarts enough oil? Some say 4, 4.5, manual says 4.25 i tink. thanks.
Old Jan 16, 2003 | 06:19 AM
PRLWHTMAX's Avatar
I too have the same noise upon startup. It kind sounds like a whizzing or windup sound under the hood. Listen to all these people who have replied because it is more than likely that the grease or lubrication inside the started has dried up. There are several DIY sites that show you how to perform this. I'm going to wait on regreasing my starter this week because of the fact that it is soooooo cold right now I'm not at my personal computer right now so I don't have the link. Reply back to this thread if you can't find the site and I will post the link. Good Luck! ~Frank
maxinout93
Oct 27, 2015 01:29 PM
conansriver
Sep 3, 2015 06:38 AM
seesole
Aug 26, 2015 11:22 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
