Max won't start correctly
Old Jan 21, 2003 | 10:52 AM
Pimp C's Avatar
ANYONE WITH SOME INFO!
My 95 Maxima has had problems starting for the last year and a half or better.......when I turn the key, it turns over.....each time I try to start it is different......sometimes it will start up right away, but often it will take a LOT to finally get it started. It's very spuratic. So far I have had the cam, crank, and knock sensors replaced with no remedy.....this problem is becoming very spendy and I don't want to get rid of my car. Any info would be great.
Thanks,
Chris
Old Jan 21, 2003 | 11:01 AM
njmaxseltd's Avatar
1) Clean your throttle body ---> www.motorvate.ca
2) Check or replace your engine coolant temp sensor, it may be out of spec.
3) Clean your engine ground points.
Old Jan 21, 2003 | 12:25 PM
ZeRo MaX's Avatar
i gotta make sure i clean my throttle body soon here.. when the car is left out in the cold for over hours.. it hesitates to start... but the 2nd try always work.. but i don't like that.. so i gotta get cleanin'...
kjlouis
Nov 24, 2018 06:09 AM
02PearlSE
Oct 7, 2015 02:12 AM
FlaMark
25
Aug 28, 2015 10:15 AM
BobMax
Aug 15, 2015 12:35 PM
kirkhilles
Aug 8, 2015 10:53 AM
