Problem... Need help!!!
Old Jan 28, 2003 | 08:22 AM
96Maxima's Avatar
When I'm driving on the highway doing about 60mph I feel the car sometimes move side-to-side alittle.... I have on a FSTB and RSB new tires.... any idea what's wrong here?
Old Jan 28, 2003 | 08:29 AM
mzmtg's Avatar
Minister of Silly Walks
Wind?
Old Jan 28, 2003 | 08:54 AM
funnylittlman's Avatar
Re: Problem... Need help!!!
Sometimes when they are repaving the road, they grove it to remove the old black top...
Old Jan 28, 2003 | 08:55 AM
96Maxima's Avatar
Originally posted by mzmtg
Wind?
no, no wind... if so, I think very little wind...
Old Jan 28, 2003 | 08:59 AM
MacGyver265's Avatar
I've noticed that sometimes it'd difficult to determine whether the wind is blowing or not. You can say "look at the trees", but when you're in an open area where there are no trees, you can't tell, and most likely, that's where the wind will be blowing hardest. I've noticed a modest gust will be felt in the steering wheel and will shift the entire body of the car at speeds in excess of 60mph.
Old Jan 28, 2003 | 09:01 AM
tomj's Avatar
Are you sure your rims are correctly seated on the posts, tires on the rims? Maybe shifting while driving? That or maybe wind from other cars when you pass them going 30 mph faster than them(happens to me all the time )
Old Jan 28, 2003 | 09:05 AM
Jeff92se's Avatar
I'm needing a caw
Could be one of about 10 different things. Go to an frame/unibody straightning shop that does alignment and ask them what is wrong. Notice I didn't say alignment shop. Most of those shops don't know WTF they are doing anyway
Old Jan 28, 2003 | 09:14 AM
mzmtg's Avatar
Check for problems with:
Tire pressures
Alignment
Tie rod ends
Wind
Uneven pavement
Heavy cargo
Hallucinatory drugs
Old Jan 28, 2003 | 10:31 AM
njmaxseltd's Avatar
Hallucinatory drugs
Old Jan 28, 2003 | 11:19 AM
Maxima95Tuner
Both mine and my mom's maximas have touring style tires on them, and since we have had those, I have noticed quite a bit of sway in the car. It shouldnt be anything to be worried about, but if you are still using stock wheels, or bit fat tires like that, it is a common problem with high quality tires.
Old Jan 28, 2003 | 11:22 AM
T-bone's Avatar
It could be the result of a wide/low profile tire following the grooves in the road. What tires are you running?
Old Jan 28, 2003 | 01:06 PM
96Maxima's Avatar
I think they're Michelin Energy MXV4 Plus - P205/65R15
“What’s wrong with that spot over there?”
“It’s too tight!”
“What do you mean too tight, you can land a f**ken jumbo jet in there!!” -- ******
Old Jan 28, 2003 | 02:51 PM
gaxima's Avatar
Sweet tires...
-Robert
Old Jan 28, 2003 | 04:22 PM
i had this problem, it was my alignment.
nadir_s
Apr 15, 2003 09:51 PM
Cabowabo
Dec 11, 2002 02:02 PM
nadir_s
Jul 23, 2002 01:11 PM
lorddeceiver
Aug 6, 2001 06:23 PM
