what is this called?
Old Jan 28, 2003 | 06:11 PM
PaulCT's Avatar
the clear plastic that covers the guages on my car is all foggy at the bottom. no matter how hard i try, it wont come off. its on the inside too. how much does one of these cost, where can i get them, what are they called exactly?
Old Jan 28, 2003 | 06:25 PM
PaulCT's Avatar
im having the glow gauges put in, and i figure i would have them put a new clear plastic cover on while the dash was apart, but they would prolly have to order it or something. is there a waebsite online i can get this at or what?
Old Jan 28, 2003 | 06:35 PM
Mad Dhan's Avatar
I dont think they sell that cover separatly, i never saw a part number on it when i took my dash apart. I would sugguest you go to a junk yard or post a WTB in the Classifieds forum
Old Jan 28, 2003 | 06:36 PM
PaulCT's Avatar
damn that really sucks. thanks anyway.
Old Jan 28, 2003 | 06:37 PM
XXXL Cracker's Avatar
Check with your local dealer. I purchased one there before. Cost me around $20.
D
Old Jan 28, 2003 | 06:44 PM
PaulCT's Avatar
hmmm- ill call tomorrow - hopefully.
Old Jan 28, 2003 | 06:49 PM
Supa Lao's Avatar
D
yup, I purchased mine from there too, after I broke it. I was trying to put on the rings around the guages and it cracked
Old Jan 28, 2003 | 06:53 PM
PaulCT's Avatar
how long will it take them to get it in?
Old Jan 28, 2003 | 07:28 PM
Supa Lao's Avatar
Got mine in about a week
Old Jan 28, 2003 | 07:32 PM
karguy's Avatar
Re: what is this called?
The fog can be removed with plastic cleaner, I cleaned mine with Meguiar's but I am sure there are other plastic cleaners available. IE. Mothers, 3M....
Old Jan 28, 2003 | 07:54 PM
95maxima's Avatar
i broke mine too while putting in the white face gauges. a new one costed me about $28. with tax.
Old Jan 28, 2003 | 11:27 PM
JPMax's Avatar
What's next!?..
Meter Lens : Part # 24813-40U00
According to my parts list.
Old Jan 29, 2003 | 12:12 AM
Speebs's Avatar
I aim to misbehave.
I used 3M Fine Cut Rubbing Compound (I believe that's what it's called). It comes in a rather large bottle that should last you a lifetime. Picked it up at Pep Boys for $7 or $8.
Old Jan 29, 2003 | 12:34 AM
Dave Holmes's Avatar
Re: Re: what is this called?
Exactly. The "fog" or cloudiness is usually caused by glass cleaners containing ammonia. There was also a Technical Service Bulletin from Nissan concerning cloudiness on the clock face from alcohol-based cleaners. Apparently, the clear plastics Nissan uses can't hold up to harsh chemicals. I use EagleOne 20/20 auto glass cleaner on mine with no ill-effects. My clock face was really bad, so I took it out and polished the plastic with Blue Magic Plastic and Plexiglass cleaner. Worked excellent. Other reputable companies' products would probably be similar. A felt buffing wheel on a cordless drill helped speed things up (Caution: a 30,000 rpm Dremel will melt the plastic because of its speed!). A lot cheaper than a new on, and if you have it out, you may as well do it. I'll be doing mine next time I take my gauge cluster out.
Dave
Old Jan 29, 2003 | 12:37 AM
spiff56747's Avatar
doh! note to self, never use glass cleaner on the clear plastic of the gauge cluster again!
Old Jan 29, 2003 | 12:49 AM
98maxsel's Avatar
mine is real cloudy too. how do you take out/off the lens???
Old Jan 29, 2003 | 03:35 AM
As for the clock, you remove the center vent cluster. The center vents and the black (or woodgrain) plastic underneath (above the AC controls) is actually one piece. Using a screwdriver with cloth wrapped around it, gently pry up on the bottom center to "pop" the clips. Then I just pulled down and out from the top. You'll need to work with it gently, but it is made to just pop out. Once out, you can unplug the harness to the clock (if doing the "clock always bright" mod from Custommaxima.com, now would be a good time), the defroster and the hazards. The clock is removed from the plastic with the 2 phillips screws. The lens pops off. Easy to do, just take your time. I also used Mothers Back to Black on the black plastic to get it spotless while it was out (I removed my entire center console and trim and did them all at once. Looks brand new again!).
As for the gauge cluster, I can't remember off the top of my head. I'll be doing it maybe today if it stops raining.
Hope this helps.
Dave
Old Jan 29, 2003 | 04:26 AM
PaulCT's Avatar
wow thanks a lot guys. i guess ill pick up that stuff today. i dont have any buffer or anything ill be doing it by hand. i really hope this works. itl save me 10 bucks. thats crazy cause my clock is like that too. thanks again.
Old Jan 29, 2003 | 07:52 AM
MChapel's Avatar
...and keep the ArmorAll(or any other "protectant", for that matter) away from any clear plastic, too.
Mar 12, 2020 12:06 AM
D Mason
Jun 21, 2016 04:43 AM
bigfrank
Oct 1, 2015 12:51 PM
maxima297
Sep 24, 2015 08:57 PM
jfl330
Sep 4, 2015 01:44 PM
