CANNOT reset my ecu!!!!!!!!!!!!!!!
I have a 99 SE and I just got done installing my PR CAI and I need to reset my computer because the CEL came on. So I opened up the little panel by the gas pedal, peeled off the plastic sheet on the little screw hole.... and nothing is there. I tried a smaller screwdriver, a little mirror and flahlight, I stuck my screwdriver all the way in the box!!!!!!! I know exactly which hole I am supposed to be in. I used to own a 95 and Ive reset the comp millions of times in that. Is there something different on the 99's? Is there any other way to reset the computer? PLease help!!!!!!!!
My brother had this problem too when he tried to do it himself. I found it though when I looked.
The screw on the 99s is a little white plastic thing located a little inside and below the hole in the ECU. Use a flashlight and shine it down at about 45 degrees into the hole. You should see it.
You'll need a small Phillips screwdriver. Really hard to feel the stop points too.
i have a 99, and you need a mini (very small) phillips screwdriver.
however the screw isn't in the middle, its off to the side a bit.
good luck!
Sweet! Thanks!
Didn't the gas pedal get in the way of you, the flashlight, and the screwdriver? Why would Nissan do this? For them to make more money and have Nissan dealerships charge you $75 to reset you ECU? Doesn't make sense.
PS- I no longer drive the 85 Tempo. Havn't changed my sig. Don't buy a Ford, even you get it for $300 and it runs. It WILL break down.
Originally posted by billy_corgan
Sweet! Thanks!
Sweet! Thanks!
don't try and stick your head near the pedals and look for the hole, just feel it out with your hand, and it should be fine.
but yes, nissan is stupid for forcing us to be in such awkward and uncomfortable positions
Just want to say that the screw is very fragile, and when you do it just turn the screwdriver by the...uh...shaft, very lightly and youll know when it stops cause it wont turn anymore without putting too much force on it. very easy to do once you get the hang of it.
OK
I went outside and tried it again and nothing!!!!!!! im getting really frustrated here!!!! Let's say you are looking at the screw hole straight on. Would I need to angle my screwdriver like 45 degrees down? up? sideways? how far in? And would I also have to angle the screw driver towards the front or back of the car? Can you give me some idea? I don't want to start scratchin the circuit board in there.
OK
OK
I had to use a flashlight and magnifying glass to see it ( I must be getting old) Once I found it I used a small precision Phillips headed screwdriver to turn it.
It is a real pain getting down into the floor mat, but it does save you from the dealer telling you that you need to pay them big $
OK
OK
If his 99 is Cali spec, will he still find the screw in there?
I think the Cali spec cars share the same ECU as the 5th gen guys. I don't think there's a screw in there.
** Billy Corgan - Please keep us updated! **
<--- 99 cali spec and ive reset my ECU ... its down there like where everyone else's is... its very tiny and adjitating... i stuck my head down there and i used one of those lil screw drivers you use to fix glasses with..... super tiny.
... it is a real awkward position, i got a muscle cramp/spasm while i was doing it.. etc etc ... lets just say its not pretty.
BUT it is down there.... good luck
OK
OK
because a normal phillips won't cut it...it has to be VERY small.
i don't remember EXACTLY, but i think the screw is towards the bottom of the hole.
do'nt bother looking in...just stick the screwdriver in and find it.
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
220k+ A32
Sep 22, 2015 03:08 PM
