CAI...dangling sensor???
Old Feb 2, 2003 | 10:19 PM
billy_corgan's Avatar
I got done intalling my PR CAI the other day and I noticed I had a sensor hanging there and I didnt know where it went. its actually not a sensor, it's a plug thats not plugged into anything. Looks just like the one that plugs into the MAF sensor, and it hangs right next to the MAF. Is this supposed to be hanging there? Could this be why my CEL is on? Anyone else have the CEL come on after the install of the CAI?
Old Feb 3, 2003 | 01:10 AM
Nismo98's Avatar
It supposed to plug in on the bottom of the pipe which is near the MAF. Look around and you'll see it.
Andrei
Old Feb 3, 2003 | 04:15 AM
PaulCT's Avatar
nice screen name
Old Feb 3, 2003 | 05:44 AM
nice screen name
Billy Corgan is the greatest songwriter/musician ever....IMHO
Old Feb 3, 2003 | 06:13 AM
I went outside and looked for where this plug is supposed to plug in and found nothing. The bottom of the pipe, as the CAI pipe? there is nowhere to plug this thing in!!! can you be more specific?
Old Feb 3, 2003 | 07:51 AM
JAIMECBR900's Avatar
There are two things it could be:
1. it may be the resistor for the tranny.
2. It could be the temp sensor for your intake.
Either way it is not detrimental for it to be hanging. You may want to take a pic and post it, so we can help.
BTW, the CEL came on because you disconnected the MAF. Pull the codes from the ecu. If it only refers to the MAF, reset and enjoy. If not, decipher the code and fix.
Old Feb 3, 2003 | 08:08 AM
96BLUMAX's Avatar
It is your intake air temp sensor. Dont worry about it. Wont affect performance at all.
Old Feb 3, 2003 | 08:11 AM
MacGyver265's Avatar
On the PR CAI upper pipe, there should be two large tubes, one small one, and a hole. The hole is on the underside and is for the temp sensor. If you have this hole there and nothing in it, you will have some "unmonitored" airflow which will cause the engine to run less than optimally, in addition to not making the temperature compensation.
I had no CEL come on after my install, but I also made sure all sensors were in their correct places and plugged in before starting the car. If you can't find that hole on the CAI, take the upper pipe off your car so you can thoroughly inspect it. It should be there, if it isn't, then you need to send it back to PR and get a new one from them. When installing the temp sensor, you need to use the stock grommet that is on the stock intake system. Its not a perfect fit, but it works fine.
When I installed my system (upper pipe only), I had the problem of having the hole there and couldn't figure out where the sensor was that went in there because I didn't remove all of the stock air intake system. I eventually found the temp sensor and installed it. No problems at all here.
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
