Sprint 2'' springs GC coilovers
Old Feb 4, 2003 | 06:29 PM
97blackSE's Avatar
hi...i want to lower my ride for an inexpensive price, without sacrificing quaility...i noticed that 1995-1999 Nissan Maxima Sprint 2.00" Lowering Coils are only $149.99..would these combines with some nice struts/shocks be the way to go...? or would ground control coilovers (374.99) be a better choice?
Old Feb 4, 2003 | 06:54 PM
97blackSE's Avatar
WHOA...did not meant to post this thread so many times!!! stupid 56k wouldn't load, so i kept clickin!!! sorry!!!
Old Feb 4, 2003 | 09:26 PM
Playboycutie69
Re: Sprint 2'' springs GC coilovers
Where can u find the sprint springs 4 that price? Cuz I need one?
Old Feb 4, 2003 | 10:47 PM
sureal00's Avatar
sprints have a nice drop .i currently have them on my car with kyb's .They are bumpy so if don't like bumpy rides you shouldn't get them. I puttin on weapon r coilovers hopefully this saturday because i want my car a bit lower than the sprints have to offer
Old Feb 5, 2003 | 05:23 AM
njmaxseltd's Avatar
Sprint springs are to low, there isn't any suspension travel left thats why the ride is bumpy. You've got to remove most of your bump stops to regain some needed travel.
Old Feb 5, 2003 | 05:29 AM
SonicDust187's Avatar
Then which combo will give nice drop on a 5speed all around and have enough travel?
Old Feb 5, 2003 | 07:16 AM
Keven97SE
Even the stock springs on the Maxima don't really have enough travel (esp the rears), so any lowering springs make the situation even worse. That having been said, I have H&Rs and the mild drop (~1.4") still allows the car to retain some ride comfort while improving handling. I cut my bump stops ~1" as recommended by H&R also.
Old Feb 5, 2003 | 08:37 AM
Juki5536's Avatar
What would be the best combination for around $500-600? Should be pretty good performance and good ride, and be able to lower a good amount. Performance/Comfort % = 40/60
Old Feb 5, 2003 | 08:54 AM
96BLUMAX's Avatar
At that range you might as well save a little more and get Jic's.
Old Feb 5, 2003 | 03:44 PM
190hpKiLLA's Avatar
Granny Driven
If you think sprints are bad try Eibach. Then we will see whats bad.
Old Feb 5, 2003 | 03:49 PM
gtr_rider's Avatar
192.168.1.1
Please explain this, I want to get this setup and I hear good and bad about them.
Old Feb 5, 2003 | 04:00 PM
BigJuice's Avatar
any comments on the ground control coilovers. I want to get that setup with some Tokicos
Old Feb 5, 2003 | 04:29 PM
matty's Avatar
I wouldnt put the GC up with the Tokicos...the stuts will blow within a year, match them up with some AGX's and your set
I have sprints and love them. I would like to be a tad lower but its good that I dont scrape everywhere I go...Sprints are a good compromise from height to ride quality, they only get bad if the road is bad, Like Any Other LOWERING Spring
-Matt
Old Feb 5, 2003 | 06:40 PM
Girliegirlmax96's Avatar
I have Ground Control Coilovers and the ride is pretty bumpy...if you put front and back down all the way its REALLY bumpy because of the rear axle our cars have. Since the back looked lower than the front, i raised the back up almost an inch and the ride is a little smoother now, though still a little bumpy. I also took my "mud-flaps" off because they kept scrubbing on speed bumps. Hope this helped!
Old Feb 5, 2003 | 06:49 PM
As far as the tokico struts, i dont know because i still have stock struts. The setup I got can be used with stock or tokico struts (and some other brand but I can't remember the name), so if you change your mind and want to run tokico struts instead of stock then you dont have to worry about which setup you have. I got my GC's from Nopi at Nopi Nationals in Atlanta last year.
Lauren
Old Feb 8, 2003 | 10:45 AM
190hpKiLLA's Avatar
Granny Driven
If ur not a hardcore racer but looking for lowest setting and the most comforatable ride with that setting look no further but SPRINT/KYB AGX. Sprints are not performance oriented but very comfortable.
Eibachs are great handeling springs and very low as well but they have SAGGY ***. They are also very harsh. If you have kidney stones look no further these will help you get rid of them.
My next maxima Im going back to sprints. I love them. BUT BEWARE they are not great handeling springs. They worked fine on the freeway doing 130 so no compaints here.
Old Feb 8, 2003 | 11:06 AM
Nick97SE's Avatar
I had both Ground Control Coilovers and Sprint Springs, and I hated them both.
I only was on GC Coilovers for 2 weeks before I got sick of them and switched them out for Sprints. They were too bouncy, and noisy. I couldn't pinpoint the noise, and the bounciness (even on smooth roads) was driving me insane. I had them with the KYB AGX shocks.
Although the Sprints were a HUGE improvement over the GC Coilovers, I really didn't like them. The handling was amazing, and the drop looked amazing, but the ride was pretty harsh. Small bumps weren't too bad, but big bumps were the problem. I even had my top strut mount fail on the driver side because I hit a bump and there was no suspension travel left, so it broke because of the strain.
I personally feel that a 2"+ drop is too much for Maxima. There is not enough suspension travel for bumps and you constantly bottom out. But if you really want the 2" drop, then the Sprint Springs are the best of the two.
I'm going to be lowering my car for the 3rd time this Spring (I'm currently on stock springs), and I'm going for H&Rs this time. They give your car a nice ~1.5" drop, and the ride is like stock, but it handles much better.
Edit: I also had the Sprints teamed up with the AGX. Forgot to mention that.
Later,
-Nick
Old Feb 8, 2003 | 11:10 AM
BigJuice's Avatar
Lauren
Thanks, that was the same setup I was looking at from NOPI also
Old Feb 8, 2003 | 02:13 PM
96shogunmax's Avatar
Re: Re: Sprint 2'' springs GC coilovers
Email the guy selling them on Ebay. I got mine for 137 shipped.
Old Feb 8, 2003 | 02:32 PM
Sprint's Avatar
blah blah blah
Old Feb 9, 2003 | 12:35 PM
This is why there are many options for the maxima. Different people of different age like different things.
Me I cant wait to put the sprints on this saturday.
MaxLvr21
Oct 17, 2015 12:11 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
Garrettz459
Sep 28, 2015 02:50 PM
followthadollar
Sep 27, 2015 01:06 PM
