Transmisson Problem Please help me
Old Feb 8, 2003 | 03:55 PM
98GLEMaxed's Avatar
I drive a 1998 Nissan Maxima and i am having a problem with my transmission. When i am braking or am stopped my car shakes. When I place my car in neutral the shaking stops. then when the car goes back into drive the shaking is back agian. I have brought the car to a nissan dealership and they can't find the problem. The warrenty expires in a couple of months. i've called nissan and they said there is nothing they can do unless the problem occurs while they are road testing my car. it has come about and they say it is normal. i know it is not because i haven't been able to see it in my friends 124,000 mile maxima. i am wondering how to go about getting this fixed. but i need to be able to get it done before the warrenty expires. i want to blow it but the last time i did that in my old car it went after the warrenty expired. so i was out the money. a little backround i baby my car te rpm's never go over 2,500 rpm's when the car is cold. i never beat on my car. no racing or heavy excelration. i want this fixed before the warrenty expires. Any help is greatly appricited. thanks guys
evan
Old Feb 8, 2003 | 05:28 PM
SamMan23's Avatar
i know this sounds crazy, but turning your rotors may take care of your problem. it's not expensive if you can do the work yourself. less than 10 dollars at autozone.
Old Feb 9, 2003 | 07:44 AM
98GLEMaxed's Avatar
all of my roters were turned a month or two back. i know it is not them. it does not vibrate when i am braking. it does it when i am stopped also. i thought the same thing. When it first happen i get all new tires on my car and had my brake's done. so i need another hint to fix this.
Old Feb 9, 2003 | 07:54 AM
96BLUMAX's Avatar
Bad idle. Tune up the car.
Old Feb 9, 2003 | 09:34 AM
98GLEMaxed's Avatar
has anyone had a problem like this with their transmission. what would it cost to change the idle??
Old Feb 9, 2003 | 10:01 AM
Kevlo911's Avatar
Kevlo for President
when was the last time ur throtle body was cleaned, it might help
Old Feb 9, 2003 | 04:48 PM
98GLEMaxed's Avatar
i have never cleaned my TB. Can i get a write-up on it? that might be what i need. Thnaks
Old Feb 9, 2003 | 05:27 PM
henock
http://www.motorvate.ca/
click "engline" on the left and you'll find it
Old Feb 9, 2003 | 08:55 PM
SamMan23's Avatar
i wouldn't go messin with the idle. idle shouldn't change unless somebody messed with it. even if changing idle takes care of problem, you would have solved a symptom and not a cause of your problem.
Old Feb 9, 2003 | 11:55 PM
96_vqmax's Avatar
Have you check your cv joint(axle).See if any thing wrong with it.
Old Feb 10, 2003 | 12:05 AM
Max4U's Avatar
IACV (Idle Air Control Valve) check it or replace it.
Does the RPM drop to about 300-400 ?
If so I recommend changing it, I had the same problem.
Old Feb 10, 2003 | 05:07 AM
taggate's Avatar
this helped in my 98 se, i flush the engine oil and trannie oil and idle got better. hardly feel it anymore and seen so improvement on gas mileage. hope this helps
Old Feb 10, 2003 | 05:20 AM
njmaxseltd's Avatar
Re: Transmisson Problem Please help me
You have a bad idle caused by a misfire or weak cykinder of some type. It's amplified through the transmission when you have the car in D or R because you now have a slight load on it.
Check your spark plugs, coils & look for a vacuum leak. Do an entire fuel system cleaning as well. (Intake and injectors) Make sure you have no codes in your ECU.
Old Feb 10, 2003 | 08:42 AM
98GLEMaxed's Avatar
well i guess all this needs to be done. but i need to make sure this is all covered under warrenty. so is anyone a pro on the warrenty for nissan? i need to find the problem as long as this is not a tranmission problem i am all set.
Old May 31, 2003 | 06:26 AM
ay5800's Avatar
did you find the problem?
Old May 31, 2003 | 04:05 PM
98GLEMaxed's Avatar
Nope still haven't. warrenty is almost over. so i need toi step on it soon!?!?!?
Old Jun 29, 2003 | 09:49 PM
raiker's Avatar
i used to have an altima and it did the same thing. it was the distrubuter.try that.good luck
Old Jun 29, 2003 | 10:31 PM
96_vqmax's Avatar
95-99 Maxima don't have distributer,we have Ignition Coil(s).
Old Jun 30, 2003 | 12:54 AM
† ErV †
no changing plugs, wires cleaning tb etc is not part of the warranty unless performed when you bring the car in for regular service maintenance intervals. Further, they will not change/work on anything unless they can prove that is that cause or if that part is indeed in need to be replaced. And it's warranty not "warrenty"...
clean the Throttle body please and check the alternator. I had a combination of both. If the alternator is a bit weak it might cause low idle etc. And your lights don't have to dim all time either.
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
homewrecker
Sep 24, 2015 07:01 PM
