rear sway bar
Old Feb 10, 2003 | 12:51 AM
Max Noob's Avatar
rear sway bar
just got my RSB in and i wana install it(90shipped 8 months used.). thing is im not too experience with any suspension stuff. i was wondering is anyone had a picture of the rear sway bar beaneath the car so i can see how it goes and where the clamps should clamp at. if there is a write up for that install somewhere on this org. pelase link. i could not find one on a search for "rsb install" thanks..laters... oh and i got a rstb too.. does that make a big difference.. or is it mainly for looks like the front one..
Old Feb 10, 2003 | 02:14 AM
Bgohan's Avatar
What brand sway bar is it? The Stillen mounts differently than the Addco. If you have an Addco, I'll take a pic of mine and send it to you. Or, go to:
Do you have instructions for mounting it?
For Stillen, go here for installation:
http://www.greghome.com/Greg's%20Garage/2002MaxSE/StillenRSB.htm
For Addco, got here for picture of installed RSB: http://rcheng.home.mindspring.com/Ma...ges/addco1.jpg
Ask a friend to help you. 3-4 hands are a big help.
Also, you may have to back-off emergency brake adjuster slightly after you are done installing RSB. You will know if your rear brakes drag when you drive off. This is not mentioned anywhere.
Good luck. Have fun on the curves.
Old Feb 10, 2003 | 02:19 PM
Max Noob's Avatar
it is an addco.. i got it used..no directions. do i need lube for the bushings or no cuz the person who sold it to me didnt give me any.? im gonna have someone help me but i want like a picture just to compare too..thanks for the links..
Old Feb 10, 2003 | 02:38 PM
Bgohan's Avatar
You should lube all the bushings lightly. Don't use a petroleum based grease.
Old Feb 10, 2003 | 03:43 PM
Weasel's Avatar
There are good instructions on www.maxima.org, direct link is https://maxima.org/shoptalk/sub_modi...sb/index.shtml
What, you thought it was just a forum?
Once you get under the car you'll see where everything goes, it's very straightforward. Good luck.
lowpost99
Oct 26, 2025 06:53 PM
matts95max
Apr 23, 2025 10:44 AM
bbsitum
Sep 11, 2015 04:55 PM
flu2000
Sep 8, 2015 02:23 PM
