Power surge after spark plug change and throttle body cleaning
Old Feb 20, 2003 | 10:15 PM
Geophrum's Avatar
i am in the process of doing a full tune up piece by piece. Today i did a throttle body cleaning and a spark plug change and alos changed the pcv valve. More to be done but....
when my wife took the car to work on the way home she noticed that the car surged at around 30 mph surging from 1500 to 1800 rpms and she even said that the lights all dimed when it did it... she was using cruse controle becuase late at night Poice in this area are bad.
i am planning on checking the codes tomorrow and i am already going to be replacing the fuel filter, o2 sensors (all 3) and also i know my knock sensor is bad so replacing that...
I am just wondering what would cause that.. could the spark plugs not be in right or is it becuase i am not done with the rest of the tune up
When i drove it i didnt feel any thing except the power inprovement... but then again i didnt go 30 - 40 mph
any ideas or should i just wait till i am totaly done all the replacements then run a code check
Old Feb 20, 2003 | 10:25 PM
maximabest's Avatar
Re: Power surge after spark plug change and throttle body cleaning
i did all that too....i recommend dont forget to clean the EGR valva, EGR pipes, if you want to replace the O2 do but i dont thing is necessary, just clean them with CB cleaner.
For you question...man, you can test your ecu anytime, if you want to do that, just do it!!!, if you want to do after all process end, do it again....is not a cheap computar that you have on you maxima.
vingodine
45
May 21, 2016 12:46 PM
Turbobink
Aug 15, 2015 07:20 AM
Samedi
Aug 13, 2015 04:05 PM
1992maximase30
Aug 5, 2015 09:27 PM
maxima297
Aug 3, 2015 12:50 PM
