Alternator trouble
Alternator trouble
I have a 95 SE and my old alternator went out. So I replaced it with one from a 96 that had 70k miles. Ever since my battery light will flicker on and off sometimes and my clock dims. I think it has something to do with the tension of the belt, but any of your opinions would be greatly appreciated. If it is the tension how tight should I make it? Thanks, James
Re: Alternator trouble
[QUOTE]Originally posted by spuljack
Could you define drive belt deflection? [/QUOTE
When you push on the midpoint of the drive belt it will move in the opposite direction. You use a force of 10 kg or 22 pounds of pressure to generate this deflection (movement). An easy way to do it is to use something that weighs 22 lbs that is connected to a loop chain similar to a dog chain then use an S hook to attach it to the drive belt. Get yourself a yardstick from Home Depot cut it so it can lay from the crankshaft pulley to the AC Pulley. The deflection will be the overlap between the yardstick and drive belt. In my case I would use a 22.5 lb dumbell. It may sound complex but it is actually pretty easy. Sorry I forgot to mention the deflection force when I first replied. I am an old car mechanic and I just push with my thumb so I overlooked it. Now you got everything you need to do it right!
TallTom
50
07-08-2022 09:54 AM
06-06-2017 02:01 PM
