heat/AC fan is making a funny noise
Old Feb 23, 2003 | 09:06 AM
nwmma's Avatar
Hi,
I was wondering if anyone else had this problem....
When i put my heat or AC on to at least the #3 fan speed funny noises come from the fan. It sounds like a bubbling noise (almost like a coffee maker) and i have a feeling there is moisture in there. I am in new england now and the weather has been very cold this winter. If anyone has any knowledge of a situation like this...please let me know
thanks
Old Feb 23, 2003 | 10:43 AM
njmaxseltd's Avatar
Are you running the A/C compressor at all? The A/C will remove moisture from the air, even in the winter time if it's run. There's a drain tube which may be clogged with debri or even ice. If thats clogged, your condensor housing might be full of water.
Old Feb 23, 2003 | 12:28 PM
cbr2's Avatar
bubbling is because you have air in your coolant.. You need to add coolant with the car running and the heat turned on high.. This will solve it.
Smackasmith
Feb 1, 2016 12:40 AM
alahjahwan09
18
Sep 21, 2015 09:12 PM
ballerchris510
Sep 11, 2015 05:29 PM
bennuss
Sep 11, 2015 05:55 AM
asianstyle
Sep 10, 2015 11:30 AM
