Front AGX Adjustment Knob Stuck and Stripped
Old Feb 23, 2003 | 09:53 PM
vmok's Avatar
Front AGX Adjustment **** Stuck and Stripped
Hi-
I was wondering if anyone has had a problem adjusting their front AGX shocks. I tried to use the little yellow screwdriver that the AGX's come with to adjust the front struts and the plastic on the adjuster **** is so weak that the screwdriver just stripped the plastic off the top. Are the top adjuster ***** supposed to be this stiff? Has anyone else had this problem? Is there an easier/better method to adjust the dampening of the front struts? Both fronts are like this. Should I use some other type of tool? Thanks.
-V
Old Feb 23, 2003 | 09:56 PM
Victim64's Avatar
Re: Front AGX Adjustment **** Stuck and Stripped
Originally posted by vmok
Hi-
-V
You are pressing down before you turn right?? Push the screw down, turn and it pops back into place....
Old Feb 23, 2003 | 09:58 PM
ch13f's Avatar
I think I read in the documentation that came with them, that you are supposed to push down before you turn, and only in one direction (ie: clockwise or counter..) but I forget which.
Old Feb 23, 2003 | 10:02 PM
Cumalot's Avatar
It doesn't matter which direction, as long as you push down on it first before turning.
Old Feb 23, 2003 | 10:04 PM
Victim64's Avatar
Yep, all it is doing is adjusting the size of the hole so it doesn't matter which way it goes
I have a feeling someone isn't pushing their screw down first though?
Old Feb 23, 2003 | 10:29 PM
ericdwong's Avatar
You can replace the adjuster, call up KYB.
Old Feb 23, 2003 | 10:34 PM
96_vqmax's Avatar
Yep,that sound like it.Alway push it down first then turn either direction then let it come up to the # with the white DOT facing the # you want to set.
Old Feb 24, 2003 | 08:34 AM
vmok's Avatar
Thanks...
Thanks for all the advice from everyone. I'll try pushing down harder tonight. I didn't know how far/hard down I was supposed to push on the adjuster and let you guys know if it works. The plastic adjuster screw seemed so soft and cheap that I was afraid I'd break it pushing down too hard!
-V
Old Feb 24, 2003 | 09:23 AM
XXXL Cracker's Avatar
Re: Thanks...
-V
Before you go home and ram it with a hammer or something. Push down firmly but you do not need a lot of force. Once it is down it will turn easily. If it is not pushed down the right way, you can and will strip the adjustment *****.
Dave
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
dvcamp
Sep 18, 2015 10:17 AM
Maxima30
Sep 7, 2015 06:13 PM
A32goldylocks
Sep 2, 2015 06:39 AM
