Estimated install time?
Re: Estimated install time?
i suppose you meant rsb (Rear Sway Bar). you can install that yourself within about a half hour. as for the STS and UDP, no clue. try to find a capable .org member in your area. good people to deal with and cheap to boot.
Licensed to Spell
![](https://maxima.org/forums/images/Maxima_OTM.png)
![](https://maxima.org/forums/images/smilies/support.gif)
Re: Re: Estimated install time?
Thanx for the responses guys. I would attempt the installs myself Mr.Potatohead but all require the car to be off the ground and I have neither a lift nor a quality jackstand (not to mention a couple of other tools that could be required). With regards to the sts install I was wondering if my custom exhaust will pose a problem?
The instructions say to "unbolt" exhaust at the cat but my system is completely welded (no bolts).
Licensed to Spell
:o)
Not to sound totally dumb or anything, but what is an STS?
Originally posted by amb4081
The ENTIRE exhaust is welded? Ohh! That might present some issues. To access the shifter easily, you have to disconnect the cat to Y-pipe connection. Otherwise, it would probably be a bear, if not impossible, to change out the shifter. It was hard enough for me and a buddy (Nissan mechanic) to do. It took us an hour approximately since we had to cut the bolts on the exhaust to access the shifter.
Re: Re: Re: Estimated install time?
Originally posted by ptatohed
No, he said it correctly dko. He said "rear asb". The correct term is, in fact, Rear Anti-Sway Bar. Everyone (incorrectly) calls it a Rear Sway Bar though.
done
The install took about 3 hrs. Would have taken less if my exhaust wasn't so complicated. The udp is amazing, 80$well spent and the rasb definetly makes a noticeable improvement. I'm not too sure what's going on with the sts though. Although i'm loving the shorter shifts, it makes some strange grinding sounds sometimes when I lift off the gas in 2nd or 3rd. The location of the entire gate has moved upwards in it's housing (neutral is farther foreward) and now when I engage 1st, 3rd or 5th, the shifter contacts the plastic trim of the console (thunk). Can anyone with this mod comment on whether or not this is normal? Thanx.
Licensed to Spell
Re: done
Licensed to Spell
Re: no
I had it done at a shop.
![Frown](https://maxima.org/forums/images/smilies/frown.gif)
![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
SmokinMax02
18
09-11-2015 12:25 AM
MaximaDrvr
08-19-2015 08:20 PM
scarletsosa
08-17-2015 09:09 PM
Team STILLEN
08-10-2015 04:29 PM
