Need help finding ignition pulse wire
Old Mar 5, 2003 | 12:28 PM
MAXimumHP's Avatar
Does anyone know if the Maxima has a diagnostic timing lead somewhere that sends a 12v pulse for each engine revolution? I was hoping someone with a FSM might be able to find something for me, please. I have a '99 btw.
Old Mar 5, 2003 | 01:06 PM
PedalKick's Avatar
Re: Need help finding ignition pulse wire
I have a 95 and FSM for that year. The wire you are looking for
ia a short loop of wire that sticks out of the main engine wire
harness were it makes a 90deg turn at the front right corner
of the engine.
Old Mar 5, 2003 | 01:30 PM
MAXimumHP's Avatar
Do you know what color the wire is? Not sure exactly where you're talking about without looking at the engine. I'm sure I'll see when I take a look though.
Old Mar 5, 2003 | 03:39 PM
1MAX2NV's Avatar
The pluse from the ECU to the ignition coils won't be 12V. I don't think any of the ECU's outputs are 12V. There are three wires going into each ignition coil. Red, black and X color with stripe. Red is ignition +12V, Black is ground and X color with stripe is the pluse signal from the ECU.
Old Mar 5, 2003 | 10:55 PM
PedalKick's Avatar
It's a wire that has a black sheath over it, about 1/8" dia.
sticking out in a loop of about 1.5" dia.
The harness is just below hood level at the outer edge of the
engine at the front right corner.
Old Mar 6, 2003 | 08:33 AM
MAXimumHP's Avatar
To 1MAX2NV's point, is this wire 12 volt pulses?
I was hoping there was a diagnostic wire that did this.
Old Mar 6, 2003 | 08:40 AM
1MAX2NV's Avatar
The red wire doesn't not pluse. The x color wire with stripe on it will pluse.
Old Mar 6, 2003 | 08:41 AM
1MAX2NV's Avatar
The red wire doesn't not pluse. The x color wire with stripe on it will pluse. When dynoing a car, that's the wire we used. So whatever diagnostic equipment you have, it should pick it up.
PH98I30
29
Feb 10, 2025 12:03 PM
MAXSE5SPD
Sep 17, 2022 04:00 AM
The Frye
Sep 2, 2021 11:03 AM
dvcamp
Sep 18, 2015 10:17 AM
doctorpullit
Sep 10, 2015 06:33 PM
