TCS System problems, I think...
Old Mar 9, 2003 | 05:55 AM
glimmer1's Avatar
I have a 99 maxima SE Limited.
I am getting a check engine light that stays on. intermittently the "TCS OFF" light and the "slip" light come on simultaneously during normal driving. When the TCS light comes on, sometimes with it, the engine will run really rough. If I shut off the car and turn it back the problem usually goes away.
I took it to the mechanic and he said error code came up as the ignition switch. He checked the ignition switch and it was ok.
If anyone has had a similar problem or if you think you may know what this is, any help would be great.
thanks
Old Mar 9, 2003 | 07:44 AM
d_hammmer's Avatar
Re: TCS System problems, I think...
thanks
Check this thread http://forums.maxima.org/showthread....readid=194925. I believe that the code your mechanic got was ignition SIGNAL not switch. Usually another code will tell you which cylinder is misfiring. Could likely ne a bad coil, or sparkplug.
DJLAX152
May 4, 2021 11:46 AM
mvm062
Nov 30, 2020 09:00 AM
Mar 12, 2020 12:06 AM
carid
Sep 9, 2015 05:06 AM
slowlifer
Sep 8, 2015 05:53 AM
