Replacing Antenna Mast - Help
Old Mar 9, 2003 | 01:43 PM
Als S2K's Avatar
I am looking for help in replacing the antenna mast onn my 96' Maxima. I bought the mast on Ebay and I took the screw off the trim. I am sure that this is a commom problem and would use the search feature to look for past posts, but the feature does not seem to be working. Any help would be appreciated. Thanks in advance.
Al
Old Mar 9, 2003 | 02:54 PM
kratz74's Avatar
Most antennas install the same. What exactly is your question. Everyting should just unscrew and plug in. No need to force anything.
Old Mar 9, 2003 | 03:02 PM
Als S2K's Avatar
kratz74,
I ended up taking out the whole motor. The base of the antenna would not come out. I ended up pulling it so hard that it broke at the base. There is still enough of the base for me to try pulling with pliers. I think it is just that it is really jammed in there. I've already tried removing every screw I could find to see if there was any screw holding the mast in. Nothing. I think it is jsut really jammed. At least I can work on in the house now ... it's freezing out there!! Thanks for the help.
Al
Old Mar 9, 2003 | 03:53 PM
95emeraldgxe's Avatar
dude dude dude - your doing it all wrong
first take off the antenna nut, then turn on your radio, and pull out the whole assembly. then put in the new antenna with the teeth facing the back of the car and have a friend turn the radio off - and the motor will suck it in, and thats it.
Old Mar 9, 2003 | 04:49 PM
Geophrum's Avatar
Im having the same problem and i cannot get teh mast out with the radio turned on or off. my next attempt is to take apart the motor. if that doesnt work i am buying it all together
Old Mar 9, 2003 | 05:03 PM
Als S2K's Avatar
I wish it were that easy. I am way past that point. When I was at that point the mast would not come out. It is so jammed in there that the mast broke. I am basically going to have to get a whole new motor. Anyone know how the "univeral" motors/antenna assemblies sold on ebay are???? Thanks.
Al
Old Mar 9, 2003 | 05:18 PM
kratz74's Avatar
Don;t force it. I did that once and dented a car. Maybe just walk away for a while and come back after you had some food and drink. Like I said, if its not coming out easy there is somehting small you probably overlooked. Antennas should just pop right in and out.
PH98I30
29
Feb 10, 2025 12:03 PM
captchaos
Mar 15, 2016 12:18 PM
dvcamp
Sep 18, 2015 10:17 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxima30
Sep 7, 2015 06:13 PM
