95-96 Red/Clear Writeup
Old Mar 11, 2003 | 08:11 PM
MikeD95SE's Avatar
I saw this a long time ago. Does anyone have the writeup on how to make the all clears, red/clears?
Thanks,
Mike
Old Mar 11, 2003 | 08:25 PM
99Maxima5sp's Avatar
Re: 95-96 Red/Clear Writeup
Thanks,
Mike
are you sure? you cant make clears for 95-96 cars, you need the all clears...i believe...
eric
Old Mar 11, 2003 | 08:28 PM
Maxima95Tuner
Re: Re: 95-96 Red/Clear Writeup
eric
You cannot make the red / clears for a 95-96 like you can for a 97-99. It doesnt look nearly as good. If you divide the whole light assembly on 1 side into 4 quadrants, the only way to make the red / clears on a 95-96 is to have 3 red and 1 clear. It doesnt look nearly as good. Ask nadir_s about it, I know he has them on his car.
Old Mar 11, 2003 | 08:30 PM
Vyrus's Avatar
Jeez does nobody read the posts anymore? He asked for the write-up on how to make all clears INTO red/clears. Mike I would answer your question but with the search function disabled there's not much I can do. Most people use Testor's Candy Apple Red spray if that helps any.
-Cyrus
Old Mar 11, 2003 | 08:36 PM
greenmax95se's Avatar
not sure of a wrti-up, but they easy to make once you got the things you need. Testors candy apple red is the right paint you need, and all you need to do is spary enough coats of it on to match up with the color of the other red on the inner trunk. Easlliy tape some newspaper to the light for covering the other half. I woudl also peel the tape of while its wet cause it can dry and possible mess up the paint a bit. Also finding a source of were to buy the all clears. people having trouble finding them now, if you find a seller, let me know bro. thanks
Old Mar 11, 2003 | 08:39 PM
-Cyrus
eric
Old Mar 11, 2003 | 09:11 PM
Jason R's Avatar
aka UNCDooD
-Cyrus
you noticed the lack of readin the original post too, huh?
Slamrod
Apr 10, 2016 05:24 PM
Maxima_Joe
Nov 25, 2015 08:19 AM
ViciousVQ30
Aug 5, 2015 05:40 PM
Max Ryder
Dec 19, 2000 06:02 PM
JULIAN
Oct 22, 2000 10:07 PM
