Charging system Problems
Old Mar 12, 2003 | 01:08 PM
96SE5Spd's Avatar
Last night I went to go start my car and the battery wouldn't turn the thing over. I had one of my friends jump me off and it started up and of course I got home turned it off and tried to start it again and nothing happened, but I really didn't get to drive it around for any signifigant amount of time before I turned it off.
The first thing everybody is going to say is that my Battery is dead or my alternator is bad, and I'm not saying that it isn't but both are new, my battery is an optima and I just put my alternator in this summer so those are the last things I'm going to look at. Also I didn't leave my lights on and none of my doors were open. My first thought was That I have to many things drawing from the battery when the car is off but I listed the ones I know out(ECU, HU, RPMswitch thats all I can think of so if I'm missing something let me know)and they shouldn't draw enough current to kill the battery unless the car sat for a week or more.
I'm totaly stummed, and am about to take it to Nissan to let them look at it but before I do I wanted to see if anybody has any Ideas or knows of something simple that I may be missing.
Thanks in advance,
Ryan
Old Mar 13, 2003 | 09:08 AM
96SE5Spd's Avatar
Nobody has any ideas?
Old Mar 13, 2003 | 09:17 AM
s2cmpugh's Avatar
my guess would be eihter a loose battery terminal connection, or the optima may just be dead, or have a dead cell. if thats the case then you should be able to get a new on for free i would think
Old Mar 13, 2003 | 01:23 PM
96SE5Spd's Avatar
I fixed the problem but now the car idles like crap but runs better than it has in a long time above 2k RPM, weird, either way it starts now.
Old Mar 13, 2003 | 01:28 PM
MacGyver265's Avatar
Was it the battery cable or alternator connection?
Old Mar 13, 2003 | 01:32 PM
96SE5Spd's Avatar
It was a dirty battery terminal, I totaly overlooked it because when I put in the optima I used that cunductive gel that is suposed to keep it from coroading, it didn't work. I cleaned the terminal and she started right up.
Old Mar 13, 2003 | 01:36 PM
njmaxseltd's Avatar
Dirty battery terminal caused a no voltage condition to your ECU for enough time to "RESET IT". In other words, the general running parameters were reset and now the ECU needs to relearn. Your car should start to run and idle better shortly.
NOTE: Resetting the 4th gen ECU by turning the screw only clears error codes, it does not "reset" your ECU. This information can be found in any service manual. Haynes tells you this in chapter 6.
Old Mar 13, 2003 | 01:39 PM
96SE5Spd's Avatar
I thought it took 24 hours to reset it? So does this mean that it is going to start pinging again as soon as it realizes my O2's are shot?
9aj9
Apr 5, 2020 12:11 AM
220k+ A32
Sep 11, 2015 02:18 AM
slowlifer
Sep 8, 2015 05:53 AM
jfl330
Sep 4, 2015 01:44 PM
