H&R wheel spacers?
Old Jan 13, 2001 | 03:41 AM
BSwithTF's Avatar
Does anyone on here have these. My rims sit just inside the wheel well. I was wanting to move them out about 1/4 to 1/2 an inch. I DON'T want it to look like a roller skate, but I would like the rims and tires to be flush with the wheel well.
Old Jan 13, 2001 | 07:35 AM
plrod Black 95 SE's Avatar
I was thinking about this myself. Post if you do it please.
Old Jan 13, 2001 | 09:56 AM
Kevin Wong's Avatar
I have wheel spacers the rear of my 89 mazda 626
I bought them for $4 at a local manufactuer. They are only 1 cm or 10 mm thick. I mounted my 96 Maxima SE wheels and 215/60/15R tires and the inside rears were barely rubbing against the strut assembly. I put the wheel spacers to fix the problem. One area of concern is the wheel studs, you have to make sure there is enought thread clearance to tighten the lugs or you may be in trouble. As long as you don't go extreme, I think you'll be ok.
[Edited by Kevin Wong on 01-14-2001 at 02:07 AM]
Old Jan 13, 2001 | 11:37 AM
selle's Avatar
Go Here <a href="http://www.nascarplace.com/hrspacers/">www.nascarplace.com/hrspacers/</a>
I have been thinking about these, too. You do need aftermarket bolts as well, but I think that those come with the kits.
Old Jan 13, 2001 | 07:56 PM
cyclemax's Avatar
I know the condition you describe (rear wheels). I considered using spacers, but you'll need the larger ones (30mm, I think) to make any visual difference (or equal to the fronts). With that size, they have their own studs, so you have to remove the stock ones and use bolts or something. I dunno, it just seemed more hassle than it was worth, but I expect they'd be fine if you did it right.
I also believe you'll slightly increase your understeer by doing this (front end plows at traction limit in corner vs the rear sliding out), so you may also affect handling.
Old Jan 14, 2001 | 01:20 AM
Turbo95Max's Avatar
Turtle turtle... Moderator
CalsonicSE has H&R wheel spacers on his 97. I installed it for him, wasnt too bad, fitment is good and it comes with longer wheel studs.
Old Jan 14, 2001 | 01:26 AM
jmax1's Avatar
Did you notice any visual difference, and how big are the H&R spacers?
Old Jan 14, 2001 | 02:12 AM
Turbo95Max's Avatar
i think he has the Concept 5 wheels. C5 imitations. 18x7.5. They looked good after the spacers. Before they looked kinda thin. Maybe he can post some pics later.
Fbana41
Aug 29, 2016 12:18 PM
Andy29
Sep 29, 2015 05:32 AM
Lowered_a33
Sep 10, 2015 09:41 PM
dcam0326
Sep 8, 2015 11:02 PM
