Fitment issues with energysuspension ?
Old Mar 15, 2003 | 06:23 AM
maxdis1's Avatar
Ok I have replaced my endlink bushings,and swaybar bushings with energysuspension bushings. Now I ordered the control arm bushings( oh this is for a 97 max) and none seems to fit! Does anyone know why ? note: I made this purchase on courtesy nissan site. The part number for the CAB set is, 7-3111G. I spoke to the sales person and they agreed to take the set back. The intresting thing is , he said that 15 people on the org. bought this set and never returned them?! Please help .
Thanks to all.
Old Mar 15, 2003 | 08:02 AM
maxdis1's Avatar
Re: Fitment issues with energysuspension ?
Thanks to all.
Please help. Bump.
Old Mar 15, 2003 | 08:32 AM
Tactics's Avatar
I remember reading somewhere that the energysuspension bushings were an exact fit, and would have to be installed with some sort of press. I could be tottally wrong though.
Old Mar 15, 2003 | 08:50 AM
marcdown20's Avatar
wow... i was looking on doing this to my car here soon... is there anyone that can confirm that this is the way that they are installed... i guess i'm glad i work at a ford dealership so i have access to these kinda tools btw... how do you like the endlink bushings and swaybar bushings?
mike
Old Mar 15, 2003 | 09:00 AM
guido_sst's Avatar
The new bushings must be installed with a press, you're not just going to slip them in and go.
Old Mar 15, 2003 | 02:40 PM
joaquink's Avatar
¿Hablas Español?
Don't send em back. Either the dealer service dept., a mechanic or a machine shop will have what you want here. Take them the control arm and the new bushings. I'm surprised you got the other ones out without a press or a lot of manual work with a drill or similar.
Old Mar 16, 2003 | 07:08 AM
maxdis1's Avatar
mike
I love the feel of the new Swaybar bushings and the endlink bushings. My car is much more responsive (similar to the 03 six speed max that I test drove). I highly recomend them. I am still confused about the control arm bushings . If anyone did this mod , kindly post some pictures.
Thanks to all that replied. Thank you guys.
Old Mar 16, 2003 | 08:11 AM
marcdown20's Avatar
i'm also hoping that it will reduce some wheel hop... did it help there also?
thanks for the reply
mike
Old Mar 16, 2003 | 09:59 AM
guido_sst's Avatar
The stock ones are generally best removed with a torch to avoid damaging the control arm and the bushing insert.
Old Mar 16, 2003 | 05:19 PM
maxdis1's Avatar
mike
The wheel hop , I am not sure about . I say that because I suck at launching ! I did however noticed less noise(in comparison with stock) while going over bumps.It is not a placebo effect; it is polyurathane(check spelling) at its best!
I felt, these bushings does more to enhance ride comfort and promote a bit more steering accuracy. Correct me if I am wrong .
Note: You might want to check your engine mounts to decrease wheel hop.
Old Mar 16, 2003 | 08:25 PM
marcdown20's Avatar
yeah i was thinkin about the motor mounts as well... i was thinkin on just going w/ all the suspension pieces first and then do the motor mounts but i guess i'll just have to see how i like everything...
btw... what kinda mods do you have up there... i got the FSTB, eibach, and agx in the front...
mike
Old Mar 17, 2003 | 06:07 AM
maxdis1's Avatar
mike
I do not have much; AGX & Eibach,courtesy FSTB, ES endlink and swaybar bushings, drop-in K&N filter, 2001 SE Muffler and Rims, AE shifer& wheel skin shift boot, Hanabi 7.5k HID kit and finally clear bumper lens with clear tail lights.
Thank for reading and I agree with you; you should start with checking your suspension , and replace worn parts first. Check tie rod ends, ball joints and wheel bearings( mine was shot).
Good luck.
Old Mar 17, 2003 | 06:59 AM
n2oMike's Avatar
Those control arm bushings are REALLY thick. Being made from rubber, there is a LOT of room for deflection. Poly bushings should eliminate a ton of slack and deflecton in the suspension around turns.
Changing the control arm bushings should make a much larger, much more noticable difference than the much thinner sway bar bushings.
Good Luck!
Mar 12, 2020 12:06 AM
conansriver
Nov 18, 2015 02:46 PM
homewrecker
Sep 24, 2015 07:01 PM
BrandonCause
Sep 14, 2015 10:41 PM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
