HELP: knock sensor - different types?
Old Mar 18, 2003 | 03:12 PM
Allen's Avatar
I bought my car used a few weeks ago and the guy that sold it told me that the check engine light came on after he added a mod chip, and nissan dealership wouldn't fix it without putting back the stock chip. he didn't want to do that so he just kept it how it was. now recently i found out that the check engine code is the one for the knock sensor. I want to get a new knock sensor and fix this but is there a possibility that the stock knock sensor (or similar ones) aren't working properly with the mod chip he put in? Or do all the chips and knock sensor interact the same with each other, meaning anyone i get should get rid of the problem?? thanks!
Old Mar 18, 2003 | 03:49 PM
NmexMAX's Avatar
dot dot dot ...
A dead knock sensor alone will not trip the CEL , only if it is coupled with another sensor error code such as a O2 sensor or EVAP something or other, I'd tell you to search.............but..........
Old Mar 18, 2003 | 03:58 PM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
if the knock sensor bad f up. would it make the engine vibrate? any indication that you might know?
http://cgi.ebay.com/ebaymotors/ws/eB...&category=6764
Old Mar 18, 2003 | 04:16 PM
Allen's Avatar
answer my question though:
"is there a possibility that the stock knock sensor (or similar ones) aren't working properly with the mod chip he put in?"
Old Mar 18, 2003 | 04:22 PM
CystumMax's Avatar
what type of mod chip he put in?
do you have ECU upgrade? do you know if he put JWT ECU upgrade in there?
Old Mar 18, 2003 | 04:27 PM
Allen's Avatar
i have no idea he is impatient and i didn't ask , and i don't know a lot about this stuff
how can i check what kind i have and whatnot?
Old Mar 18, 2003 | 04:30 PM
CystumMax's Avatar
I would say he probebly have added that stupid resistor mod. to make fuel ratio changed. but i'm not sure where that resistor mod is installed. hopefully someone will know and help you out. if you pull that out. it will fix the problem.
TallTom
57
Oct 14, 2025 05:16 PM
hayne
Oct 5, 2015 11:53 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
