Pulled 0201 ECU code
Old Mar 18, 2003 | 08:31 PM
WizzaMax's Avatar
This translates to Ignition Signal Circuit failure...
only thing I got from the tune-up manual is that the ECM is not seeing voltage from the ignition switch...I cannot for the life of me figure what may have prompted this code...
the only thing that touched the ECM is the key coder from the dealer the other day to get a chipped key programmed...but that did not have any errors or problems come up on the keys...so I am looking for more information on what would be the fix for this MIL code.
Old Mar 19, 2003 | 05:19 AM
infinitiblast's Avatar
It could also be your coil packs I hear. I got the p1320 code on the obd2 scanner primary ignition ciruit failure something like that. If it drops a coil you can get that code too. What are your symptoms?
gustavison
Oct 4, 2015 06:50 PM
220k+ A32
Sep 22, 2015 03:08 PM
QueensMAX
Sep 15, 2015 04:14 AM
