gauge bulbs
Old Mar 19, 2003 | 08:41 AM
pavelsmax's Avatar
gauge bulbs
im sittin at home pretty bored and im thinking about changing my dash bulbs to red...i cant find the page with the instruction however...any one done this and had any problems or any tips for me...thanks in advance
Old Mar 19, 2003 | 08:55 AM
97MaxGurl's Avatar
Chick specializing in rounding up 100+ Maximas
Re: gauge bulbs
you'll have better luck finding write-ups on how to install indiglo gauges. It's essentially the same procedure, minus the need to open up the front cluster cover since you don't need access to the speed instruments. Good luck.
Ange
Old Mar 19, 2003 | 09:50 AM
pavelsmax's Avatar
still lost
damn i have been searching for an hour and i still cant find n e thing
Old Mar 19, 2003 | 10:06 AM
4GRookie's Avatar
http://www.geocities.com/amixam69/nissan/dash/
You can thank me later.
Old Mar 19, 2003 | 10:12 AM
97MaxGurl's Avatar
Re: still lost
1 Set the height of the steering column to the lowest it can go.
2 Remove the plastic bottom cover to the steering column, it's the piece that's above your knee. There are two screws near the bottom, and then pull out.
3 Remove the Metal shield covering the bottom of the steering column. Two 10 mm bolts here.
4 Remove the bolts holding the steering column up, two 12mm bolts. Use the extension if you have trouble reaching up in there. Drop the steering column down.
5 Unscrew 2 screws holding in the top of the dash, it's the plastic cover underneath that overhang.
6 Pop down the top half way. Using some firm BUT consistent pressure, pull back on it, removing the cover from the dash. There are four little clip holes red arrows) that are holding it in, so besure to find those clips. Remove the three screws holding in the dash cluster.
7 Unhook the four clips in the back so you have access to the back of the cluster.
Write-up can be found on the How-To Section of http://maximadriver.com/
AnGe
Old Mar 19, 2003 | 10:15 AM
pavelsmax's Avatar
thanks a lot
thanks a lot guys im goin to give it a shot thanks!!!
Old Mar 19, 2003 | 02:53 PM
pavelsmax's Avatar
thanks
i changed the gauge lights key ring and shift lights they look sweet ill post some picks later thanks
Old Mar 20, 2003 | 08:26 AM
pavelsmax's Avatar
red bulbs
i got some pics up on my homepage check it out thanks again for ur help guys...ill do the window switches and climate stuff next
Old Mar 20, 2003 | 09:26 AM
redmaxpa007's Avatar
i SeE what you did therE
looks good..
Miket2006
Mar 1, 2021 03:55 AM
doctorpullit
Mar 29, 2016 11:08 AM
mpbclutch33
Dec 26, 2015 11:11 AM
knight_yyz
Nov 1, 2015 01:34 PM
Noela
Sep 26, 2015 08:22 AM
