0505 No Failure Recorded/Detected
Old Mar 20, 2003 | 12:25 PM
mddecker's Avatar
So I pulled an 05 05 off my ECU. Went to the decoder and it diagnosed it as No Failure Recorded/Detected. Does this mean that there isn't a problem and I should just reset the ECU? Or does it mean that I read the code wrong and its not in the database?
thanks
Old Mar 20, 2003 | 12:27 PM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
Re: 0505 No Failure Recorded/Detected
thanks
It means nothing is wrong with you car. and dont disconnect the battery. you all good.
Old Mar 20, 2003 | 12:31 PM
95SEking's Avatar
I have had this problem since I bought the car 6-7 months ago. My CEL comes on and stays on all the time. When I check it I only get 0505. I have asked the forum a couple of times and no luck helping. Any clues?
Old Mar 20, 2003 | 01:27 PM
GoldMax99's Avatar
When I first bought my car it did the same thing. I have a 95 Max GLE. When I first pulled the code, I saw that the screw was not stopped properly. Make sure you reset the ECU and that the screw is left all the way counter-clockwise, against the STOP! And don't overturn it!!!!
Old Mar 20, 2003 | 03:58 PM
95SEking's Avatar
Thanks I will try that today. I have tried a couple of other things and nothing has worked yet. I just have gotten used to driving around with that stupid yellow light on.
Old Mar 21, 2003 | 05:52 AM
GoldMax99's Avatar
Remember King, don't overturn it and you must reset the ECU first so that the light turns off.
If you want to test that this is the probable problem and solution, I noticed that if you turn the key to the On position for a little while wait for like 15-30 seconds and then start the car, my ECL light would not turn on. If this happens to you too then, it's probably the screw. If not, then it could be something more serious, like a faulty ECU.
Roymg
Sep 3, 2018 05:10 AM
The Wizard
24
Oct 1, 2015 08:47 PM
ac max 92
Sep 17, 2015 07:35 AM
BamaMax
Jul 13, 2003 09:02 PM
Max96LSU
Jun 5, 2001 02:34 PM
