installing AE pedals...
Old Mar 21, 2003 | 04:47 PM
Black97GLEnj's Avatar
I cant seem to figure out how to remove the gas pedal to put the new one on. As for the brake pedal, any advice on how to make it a little easier?
Old Mar 21, 2003 | 05:02 PM
Jepht20's Avatar
Custom User Title...
for the brake, someone once said something about boiling it to make it more flexible. i just used a short but fat flat head screw driver and kinda pried it on. hard but after a while you'll figure it out. as far as the gas pedal...are you replacing the whole arm or just pedal? just unsnap the piece on the stock one and slide it off. it's hard installing the ae one cuz it doesn't fit snug...so you need to either wedge something in there so it stays tight, or think of something else. you kinda have to invent a lil and work with them to make them both fit tight but they work. sorry if this is vague, but basically just keep trying and you'll get it. g'luck
Old Mar 21, 2003 | 06:08 PM
I got the brake on by boiling it to soften it up. The gas doesn't want to fit. It is just the pedal, not the whole arm. The AE gas pedal didn't come with a new clip, so I cut the old one off, but it isn't fitting. Any ideas?
Old Mar 21, 2003 | 06:13 PM
Jepht20's Avatar
i also used the clip from the old one...i put it on and then used rubber bands to secure it. i know it sounds sketchy but it works.
Old Mar 21, 2003 | 07:09 PM
WizzaMax's Avatar
what I did was remove the clip by cutting with razor and trimming to fit the new AE pedal clip holder...about 1/16" trim off the edge depending on how close you want it to fit...then wrap electrical tape about 3/8" thick all the way around the bottom of the peg as the gap has to be taken up to prevent shaking/rattling.
enjoy...
Old Mar 21, 2003 | 07:31 PM
thanks everyone...
I used a file to trim down the clip, and also filed the edges of the ae pedal where the clip attaches. I used electrical tape to hold the bottom part snug. It was more of a pain in the azz than i thought, but it looks good.
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
