Test Pipe Installation
Old Mar 24, 2003 | 08:49 PM
speedemn's Avatar
I have a Budget y-pipe and b-pipe installed right now, with the stock cat. I have a Budget test pipe that I tried to install on Friday. I noticed that the stock cat has 2 bolts on the y-pipe end that is attached to the cat itself. As a result I was not able to swap out the cat for the test pipe because I didn't have any replacement bolts. I was wondering if anyone else ran into the same problems.
I can't take it to a local muffler shop obviously since it is a test pipe. But I was wondering if anyone did run into the same problem as I described and if you did, what bolts did you get to replace the 2 bolts between the y-pipe and cat/test-pipe.
Thanks.
Old Mar 25, 2003 | 03:03 PM
speedemn's Avatar
^^ bump ^^
Any thoughts?
Old Mar 25, 2003 | 03:21 PM
stephenlc's Avatar
Dude just go to the Nissan Dealership and buy 2 from them, can't cost that much, get a crush gasket there too if you need one.
Old Mar 25, 2003 | 03:28 PM
ejj's Avatar
ejj
Um...you can get nuts and bolts at any hardware store. There doesn't need to be anything special about them.
Old Mar 25, 2003 | 03:33 PM
speedemn's Avatar
Well, I was at Costco since my buddy works there and we were able to prop it up on the hoist. He said that they didn't have any bolts there that would work.
I don't know what size to buy at the store and I didn't want to take one bolt out and run on 3
Old Mar 25, 2003 | 03:36 PM
ejj's Avatar
ejj
Go to home depot (or something similar). Get 2 bolts that are at least 3" long...get 2 matching nuts for the bolts and 4 washers who's outer diameter is bigger than the hole in the test pipe and ypipe, and who's inner diameter is bigger than the diameter of the bolts.
2 washers on each bolt, one on each side of the flange. They don't need to be metric, or the exact diameter that Nissan uses, etc. Just nuts and bolts.
Old Mar 25, 2003 | 03:52 PM
redmaxpa007's Avatar
i SeE what you did therE
yes.. that is exactly what you need to do..
Old Mar 25, 2003 | 04:37 PM
Flava_24/7's Avatar
Boosted Panda
Just make sure they are grade 8. If not the heat could cause them to break.
Old Mar 25, 2003 | 05:32 PM
ejj's Avatar
ejj
I think that's overkill. The heat at that point in the exhaust isn't that extream.
Anything (metal of course, not plastic) should work.
Old Mar 25, 2003 | 05:39 PM
99Maxima5sp's Avatar
let us know what that sounds like...also, is there anyway to trick the ECU to not trip?!
Eric
Old Mar 25, 2003 | 06:52 PM
speedemn's Avatar
Eric
Hopes and dreams? I dunno... I can't do a search so I can't check on past history of other 95 Maxima guys. But I do remember that a couple of guys didn't have any issues. I am hoping that mine works out the same way.
MaxLife17
Jun 27, 2019 01:37 PM
BkGreen97
Apr 2, 2016 05:47 AM
MaxLife17
Sep 8, 2015 02:36 PM
Maxima30
Sep 7, 2015 06:13 PM
Johnny9595
Sep 3, 2015 05:18 AM
