Wheels Alignment on MAXIMA
Old Mar 24, 2003 | 09:47 PM
TSW's Avatar
TSW
Wheel Alignment on MAXIMA
Hi guys,
I have changed rims & tires from 215/55-16 on 245/45-18 on my babe and I noticed it pulls to one side a bit. I would like to know if the alignment is done on the front wheels ONLY for our 4th generation MAXIMAS, right?
Rear wheels cannot be aligned, am I correct?
Thanks guys.
P.S. Drive and take care of those SWEET looking 4th generation MAXIMAS…..
Old Mar 24, 2003 | 11:37 PM
krbga's Avatar
I have had 4 alignments...
They will have to do a 4 wheel alignment to get "All 4 wheels centered and aligned in the same direction" Make sure you do the following before you go to get an alignment:
1. Balance the Wheels/Tire
2. Check for even tire pressures
3. Have the balancer check if any of your tires are "out of round" it then can be replaced under the tire manufactures waranty.
When you have an alignment have them double check your Tie Rods. I had to have mine changed out soon after my 18inch upgrade. These have to do with the steering/slight pulling/slight drifting..esp on the highway.
Old Mar 25, 2003 | 04:09 AM
genepool's Avatar
Re: I have had 4 alignments...
They can not align the rear wheels.....there is nothing to adjust. I think the alignment they will give you is a thrust alignment, IIRC, will make sure your car travels in a straight line. Don't pay for a 4 wheel alignment.
Also, I never heard of tie rods wearing out, usually they are replaced because they are bent from an accident of some sort.
Old Mar 25, 2003 | 07:32 AM
ZeRo MaX's Avatar
I also have a question about slight pulling/steering...
I go straight... but it seems like sometimes i'll slowly steer one direction... especially on bumpy roads
I put my 18's back on... 225/40/18... and lowered it with sprint springs (2 inches).. and now I need an alignment.. i've been waiting for camber kits... but i drive to work and school everyday for about 40 miles a day... should I Get my alignment ASAP?
Old Mar 25, 2003 | 07:36 AM
ZeRo MaX's Avatar
what's the difference between camber bolts and the camber kits?
Old Mar 25, 2003 | 07:38 AM
vipervadim's Avatar
I like Maximas
i think i have the same problem.
i go in straight lines and everything but my steering wheel is kinda hard to turn (but then again i just made a transition from an 89 olds where the steering wheel can be easily turned all the way with your pinky finger!) and then i stop on a somewhat bumpy road sometimes my steering wheel pulls to the right, or to the left. what can be causing this?
I do plan to flush out and replace the steering fluid with Royal Purple ATF.
-Vadim
Old Mar 25, 2003 | 09:44 AM
BigJuice's Avatar
-Vadim
This was my problem exactly on my 91 max. I went and got an alignment and my brakes done and it still did the same thing. Only recently I have suspected that It might be my tires
I just took the same setup from my 91 Max (18 in Konnig Toxxins/ Yokohama paradas) and transferred it onto my 1999 SE and it suddenly started doing the same thing so I will go and check my tires.
Old Mar 25, 2003 | 11:58 AM
vipervadim's Avatar
I like Maximas
yup my tires are the stock bridgestones that came with the se rims! they have 61K on them and have about 10% (at best) trread left on them i went to tirerack and found some pretty nice Kumho Supra 712's for 72 each. i'll probably end up getting those.
CRizz
41
Jun 7, 2021 05:42 AM
trasmadean
Feb 1, 2017 08:20 PM
morteljc
Wheels/Tires
Oct 22, 2015 08:43 PM
Flores94
Aug 11, 2015 12:53 PM
BassAddictJ
Aug 4, 2015 11:38 AM
