Delay in MEVI butterly valves opening??
Old Mar 25, 2003 | 09:58 AM
I30tMikeD's Avatar
I have my harlan set at 5K but it does not seem to open till almost 5400K. The test was done with the car not underload. Do you think that makes a difference? Would it open differently when accelerating in gear. Maybe it's because when I rev it in nuetral the rpms climb so fast the switch is delayed a bit. What do you guys think??
Old Mar 25, 2003 | 10:15 AM
Nealoc187's Avatar
SLOW
Are you giving it full throttle in neutral? If so then yeah that would explain a delay because it is revving up so fast. Try setting it at 2000 and doing the neutral thing again, but slowly rev from like 1800-whenever it opens so you can tell.
Old Mar 25, 2003 | 10:20 AM
I30tMikeD's Avatar
No I wasn't going full throttle. Good idea I'll try that this afternoon.
Old Mar 25, 2003 | 10:39 AM
Dave B's Avatar
Not DAVEB the parts guy
I know that when I'm at WOT in 2nd or 3rd gear, I don't hear the resonance change until an indicated 5500rpms (5200 switchover). Remember that the stock tach is off by about 200-300rpms.
Dave
Old Mar 25, 2003 | 10:56 AM
XXXL Cracker's Avatar
Our tachs are definitely off to echo Dave's statement. Best way to test is by setting at low RPM setting and have the light on the switch visible to you from the cabin. Determine if light is coming on at set point.
Easier is to get a friend to help you as mahy people have their RPM switch in the engine bay.
By mounting mine in the cabin, I can test it to determine if the switch is getting the signal at the set RPM point.
D
Old Mar 25, 2003 | 11:02 AM
Nealoc187's Avatar
SLOW
D
With your hood up you can see the activation of the MEVI itself, no need to look for the light and hope the MEVI is opening at the same time
Old Mar 25, 2003 | 11:17 AM
I30tMikeD's Avatar
Ahhhh....I never thought of that.
litch
123
Jan 4, 2024 07:01 PM
Miket2006
Mar 1, 2021 03:55 AM
howardis
Dec 11, 2019 06:10 PM
TKHanson
Nov 24, 2018 01:39 AM
tseng1023
Oct 15, 2015 08:30 AM
