Need help with Corner Lights
Old Mar 25, 2003 | 09:01 PM
Grimzar's Avatar
I did the diagram that I saw on the faq in this board and another faq from http://www.danimsta.com/bright.html. There was also one from maximadriver.com but it involved soldering so I said forget it. I followed the one from maxima.org faq instead of http://www.danimsta.com/bright.html. Maxima.org faq said to clip the **** on the top the other said the bottom , anyways I clipped the top one and put electrical tape on it but it still didn't work. Can anyone help me with this?
Old Mar 26, 2003 | 07:04 AM
Tuna's Avatar
electrical tape.?? you cut the top nub off, sand it down so it will nice and smooth.. then you just put it back in the socket but you turn it 180 degrees (meanin that you put it in the opposite way it used to go in before).. then turn on ur parkin lights and check it out.. the brighter filament should turn on.. oh yea, this mod will only work on 97-99's, if you have a 95-96 then it will just reverse its workin order (meanin that when you put ur parkin lights on it will be bright and when you turn ur signal on that side will be dim)..
hope this helps..
DJLAX152
May 4, 2021 11:46 AM
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
