Front end alignment problems
Old Mar 26, 2003 | 11:39 AM
mandmmax's Avatar
What do I do if the caster is out on my Maxima? The camber is right on, but the vehicle pulls left. When having it aligned, the measurements indicated that the left caster is less positive by about 0.8 degree. I know the factory does not specify adjustment specs for the camber or caster. I saw what you said about having the mechanic adjust the lower strut bolt to adjust the camber, but is there a way to adjust the caster?
Old Mar 26, 2003 | 12:07 PM
njmaxseltd's Avatar
Caster cannot be adjusted. If your caster is off, something is bent. Most likely it's your lower contorl arm.
Old Mar 26, 2003 | 12:16 PM
mandmmax's Avatar
Is the lower control arm a replaceable part?
Old Mar 26, 2003 | 05:39 PM
† ErV †
yes
Old Mar 27, 2003 | 05:05 AM
Juki5536's Avatar
Are they expensive? Because my car is pulling to the left also, and I'm going to take it to FASHIZL (hopefully soon) to get the alignment fixed, maybe I have the same problem...Hope it aint too much, I'm broke!
boomerbrian
Nov 8, 2015 05:10 PM
JoshG
21
Sep 4, 2015 09:04 PM
homeyclaus
Sep 3, 2015 06:15 PM
official_style
Aug 29, 2015 10:10 AM
Samedi
Aug 12, 2015 01:54 AM
