Replacing pcv valve helps cure ACT clutch chatter!
Old Mar 27, 2003 | 11:15 AM
Stephen Max's Avatar
This was totally unexpected. I read in another thread that an unsteady idle that drops below 650 rpm might be caused by a bad pcv valve, so I picked one up yesterday and installed it last night. Sure enough, it cured the idle drop, but driving it around during lunch time today, I noticed something else - I didn't have to rev the engine up nearly as high as before to keep the ACT clutch from chattering during a roll from stop! I couldn't believe it. Apparently the pcv valve's functioning during idle and tip-in helps keep a steady rpm at idle and low rpm, and my bad pcv resulted in a fluctuating rpm that resulted in clutch chatter. For the first time I was able to start rolling without touching the gas pedal (it used to die before, or else the clutch would chatter so much it was awful), and the clutch action starting out is so much smoother. Woohoo!
Old Mar 27, 2003 | 12:06 PM
maxspeed96CT's Avatar
The original VQ...
This is weard. Maybe you clutch just wore in finally. But i might try it cause i need to replace my pcv anyway.
Old Mar 27, 2003 | 12:15 PM
supercobraz's Avatar
How long did it take to replace the PCV valve?
Old Mar 27, 2003 | 12:29 PM
Maybe so. But that would be quite a coincidence.
Old Mar 27, 2003 | 12:32 PM
About 20 minutes, but that's because I broke the rubber hose that the pcv valve connects too. It had become brittle with age. I spent about 10 minutes finding the right diameter hose in my box of automotive odds and ends.
Old Mar 27, 2003 | 01:00 PM
Ok thanks, I suppose I should change mine. I removed the hose the other day and attempted to remove the hose and it didn't budge, so I left it alone. I'll do it this weekend.....Thanks again
Old Mar 27, 2003 | 01:01 PM
xHypex's Avatar
Sounds logical to me. Anything that helps you maintain steady rpms while engagine the clutch will reduce clutch chatter.
-hype
Old Mar 27, 2003 | 02:05 PM
karguy's Avatar
That's great! Not a bad improvement for a $5 part. The longer I am on the forum themore convinced I become that preventive maintenance is to key to a good running ride!!
lux97Max
19
Aug 27, 2015 07:48 PM
shaunkey1
Aug 18, 2015 10:09 PM
vanebecker
Aug 17, 2015 08:24 PM
doobadoo
Aug 15, 2015 06:43 PM
Gsantos79
Aug 8, 2015 07:41 AM
