Help w/ Corner Light (Another Thread)
Old Mar 27, 2003 | 11:47 AM
gabex's Avatar
Ive got a 95 and Ive been reading all the recent threads, so I tried it.. I got as far as cutting off the lowest nub... and then I'm stuck... I put the bulb back in, and my lights are how they were before.
Old Mar 27, 2003 | 12:07 PM
gabex's Avatar
Re: Help w/ Corner Light (Another Thread)
A recent post said to cut the lower nub... so I did.... the FAQ's said to cut the higher nub...***! Which one is right?
Old Mar 27, 2003 | 12:46 PM
MacGyver265's Avatar
Just cutting the nub won't make any difference, you have to rotate the bulb in 180 degrees from the way it would normally go in too.
Old Mar 27, 2003 | 12:50 PM
gabex's Avatar
Well, the bulb wouldnt fit if I turned it 180 degrees (I cut the lower nub).
So I got out my old amber bulbs and decided that I'd try to cut the upper nub to see the difference.. Sure enough it worked...they fit after I turned them..
Are my Polarg bulbs ruined now? They only have the upper nub..
Old Mar 27, 2003 | 01:06 PM
njmaxseltd's Avatar
Your 95 has cornering lights. They get bright when you put your directional signal on. Don't turn the bulb around or cut anything. You have the option that most on here would love to have. Why Nissan dicided to omit that nice feature from 97 up is beyond me.
Old Mar 27, 2003 | 06:56 PM
gabex's Avatar
Wow I've not seen you post in a while... I dont quite understand what you mean..I was trying to get my corner lights to be always bright.. because I had Polarg's in them, and I wanted it to look like my corner lights and headlights were 1pc (bright all around) at night..But maybe I was going about it the wrong way.. I only put some old amber bulbs in them just till I order new Polarg's..
Old Mar 27, 2003 | 07:24 PM
Tuna's Avatar
what he means is that if you put the bulb in the way it's supposed to the dim filament turns on with ur parkin lights and when u turn ur turn signal on, on that side, the corner light gets brighter due to the bright filament comin on.. if u reverse the lights then it will be bright until u turn on ur signal and then that side will be dim until u turn ur signal off.. kinda confusin..
Old Mar 27, 2003 | 07:27 PM
Naija's Avatar
MacGyver265 was right, all you really have to do is turn the bulb around 180, which is the reason why it's easier to do this when both of the off nubs are cut off. The function of the nubs is to lock the bulb into the socket, so if you cut off one of the nubs or even both you will be alright as long as you are able to find another way to secure the bulb in the socket...
since you are getting another set of polarg's, can I take your old set off of your hands?
Old Mar 27, 2003 | 07:32 PM
gabex's Avatar
Interesting.... maybe I'll have to mess around with that because polarg's werent cheap $23 for the pair
mvm062
Nov 30, 2020 09:00 AM
markevans999
Sep 10, 2015 04:29 PM
Maxima30
Sep 7, 2015 06:13 PM
JoshG
Sep 5, 2015 10:10 PM
FanaticMadMax
Sep 4, 2015 02:45 PM
