question about changing ATF
Everyone has at least the stock cooler, it's built into the trans. On the transmission side, the lower hose is the return. I usually purge mine for the pressure side of the trans (top line), just 'cause it's easier. 3 or 4' of 3/8" hose from there to a bucket and you're all set. Just drain and fill the pan first, and again after each gallon or so. Yes, it leaves a little old oil in the cooler, but not enough to worry about IMHO.
sdotcarter
09-02-2015 09:53 PM
