IACV changed but got Qs.
Old Apr 2, 2003 | 01:31 PM
SonicDust187's Avatar
I just changed the IACV on my 98, however the one that I took out has this brass covered cap type on the back in the center of the valve, however, the new one doesnt have it. Do I need to install this brass cap on the new one also? Second my idle still fluctiates, sometimes its at 600rpm other times its at 700rpm and it doesnt stay even. What do you think the problem is?
Old Apr 2, 2003 | 02:56 PM
I was just listening to my car and the new IACV clicks faster and louder then the old one. Did I fu** something up?
Old Apr 2, 2003 | 03:04 PM
Mishmosh's Avatar
You do not need to install the cap. I am assuming you bought a new IACV from your dealer.
As for ticking, if it is really loud, I don't think it's supposed to do that normally. When my battery was drained recently, after I jumped it, for some reason the IACV was ticking loudly about once a second. It was only briefly and doesn't do that now.
As far as wavering idle, make sure that you have set the idle rpm correctly--I would definitely check it after installing an IACV or doing something like cleaning your throttle body because it is easy to knock off range. If the set idle rpm is off drastically, the ecu will be constantly fighting to correct it and you may get a wavering idle for that reason. Also insure that you don't have a manifold/intake vacuum leak somewhere and that your PCV valve is good.
Old Apr 2, 2003 | 03:13 PM
bill4max's Avatar
I have a 97 and my iacv valve clicks at idle too is this not normal for our cars? If this is not normal why are ours clicking?
Old Apr 2, 2003 | 03:15 PM
I just put in new PCV valve. Maybe the IACV is adjusting to the engine since its brand new. Ill give it time but I dont have a lot of it. How long did it take before the sound went away? Anyone else?
Old Apr 2, 2003 | 09:18 PM
matty's Avatar
maybe its your injectors clicking...look closer
as for the brass cap(held in by 3 little screws), Yes you do need to install that...take the one off your old one and put it on your new one but clean it first before you install it..
-matt
Old Apr 2, 2003 | 09:53 PM
JsL's Avatar
JsL
I've never notice anything clicking under the hood. The IACV is the idle air control valve (?)and it's in back of the throttle body right?
Old Apr 2, 2003 | 11:06 PM
lp's Avatar
lp
Mine clicks at idle also, and only started doing it immediately after I'd removed and cleaned it.
Hasn't affected my idle at all, its still very solid. I've removed, re-cleaned and replaced the IACV gasket but that made no difference. Its silent until the engine gets to operating temp and low idle is reached, then the IACV starts clicking (like mentioned above, roughly once per second).
The IACV FSM test procedure is another thing on my 'to do' list.
Old Apr 3, 2003 | 04:29 AM
The brass cap on the old IACV has 3 bolts however on the new IACV the are no holes for hte bolts to hold the cap in. Are you sure I need it?
Old Apr 3, 2003 | 07:21 AM
matty's Avatar
Yes you do, it regulates the air going in and out..where did you purchase this new one at ??
Maybe its for a differnt year like a 3rd gen or something..
-matt
Old Apr 3, 2003 | 08:03 AM
-matt
Jerry rome nissan. The new one looks exactly the same however the brass colored tube is londer on the new one and there are no holes in teh back to mount the brass cap to. I hope they didnt sell me the wrong part.
I belive my part # was 23781-38U05.
Old Apr 3, 2003 | 04:03 PM
Mishmosh's Avatar
You do NOT need the cap. Perhaps we are talking about different things. The black plastic screw (not the cap) is what allows for some air entry adjustment to fine tune idle speed. As SonicD says, the newer IACV does not even have threads for the cap. I am guessing it's function is to minimize "soot" clogging up the sensor port.
Old Apr 3, 2003 | 08:59 PM
But still should it be ticking so loud and every dam second?
Old Apr 6, 2003 | 05:38 AM
D1NOnly34's Avatar
I don't know about every second, I never really noticed a clicking sound till like 3 weeks ago. My IACV only clicks when I turn my wheel a certain point in both directions. But thats about it.
Old Apr 6, 2003 | 11:57 AM
Mishmosh's Avatar
OK, I just popped the hood and noticed that the IACV does make a clicking noise about once every second. It is not loud relative to other engine noises at idle and certainly, I can not hear it from the cabin. The loud clicking I've only heard once from my IACV was clearly heard from the cabin but like I said, went away--or at least quieted down to normal levels.
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
Need help
23
Oct 2, 2015 08:56 AM
Noela
Sep 26, 2015 08:22 AM
