$500 + Parts: Clutch job on '96 SE 5-Speed? Too much? Clutch failure symptoms?
Old Apr 3, 2003 | 09:16 AM
Bernout's Avatar
I can't get my shifter into gear hardly. The pedal is very stiff and must start the car in gear or I won't be able to get going. From there its a battle to get to the next gear. There is no slipping though.
I was told by a local shop that its going to be $500 PLUS parts. Is that accurate? What do I need specifically?
Anyone recommend an aftermarket clutch?
Thanks all.
Old Apr 3, 2003 | 09:25 AM
Cumalittle
Re: $500 + Parts: Clutch job on '96 SE 5-Speed? Too much? Clutch failure symptoms?
Thanks all.
500 for labor sounds rite...
Old Apr 3, 2003 | 09:32 AM
alexg240's Avatar
It sounds to me like its your slave cylendar, but it could also be your clutch throw out bearing siezing up but i think its your slave cylendar 500 labor is not too bad
Old Apr 3, 2003 | 10:54 AM
Bernout's Avatar
Thanks, slave cylinder or throw-out bearing? I will mention that to the tech.
But 500 is not too good either.
Old Apr 3, 2003 | 11:44 AM
Cumalittle
dont misunderstand...a clutch work for 500 is good...replacing slave cylinder for 500 is expensive...
Old Apr 3, 2003 | 12:43 PM
Prodeje79's Avatar
I had my master or slave cylinder replaced, I forget which. That is way higher than what I paid though, I think I paid $50 tops for just labor. The way I noticed my clutch was bad was that I would WOT in 5th gear and my RPMS would shoot up then come back down and "catch" and then accelerate..........
Get some free etimates from various places maybe
Old Apr 3, 2003 | 01:45 PM
MaxSE98's Avatar
wow 500 plus parts ? i do them in my garage for 250 plus parts and all my experience is in maximas .. my best time for pulling everything out of my car is 2 hours 20 minutes if your in CT let me know man ill help you out and i can show you how to do it at the same time -pete
Old Apr 3, 2003 | 01:48 PM
97blackSE's Avatar
WHERE THE HELL WERE YOU WHEN I SPENT 500+ IN LABOR ON MY CLUTCH IN FEB!?!?!?!
Old Apr 3, 2003 | 02:24 PM
MaxSE98's Avatar
probably in my garage lol
ive been trying to sell my maxima
im building something with alot more potential
i do it all (xept bodywork) lemme know if u ever need anything
Old Apr 3, 2003 | 03:55 PM
kerzhulzad's Avatar
I had some problems getting into 2nd gear for a while on my '97SE but after the dealer flushed the transmission fluid, things because a lot better. Maybe that's something to try before shelling out a ton of money for a new clutch.
Still on my original clutch after 120K miles.
Old Apr 3, 2003 | 05:10 PM
MAXSRB's Avatar
Whoa dude, nice lookin Z. Im guessing thats your ride with more potential right there. Dropping in a V8 into one of those badboys is like riding around in a supercharged viper. My buddy is planning on building a Z after he's done with his DSM. Im also very interested in Z's myself, but i havent the money for the hobby....yet. Again nice Z. How much HP you expecting from it...?
Old Apr 3, 2003 | 08:14 PM
96shogunmax's Avatar
Thanks all.
Well mine wouldnt get into gear either. (Air in the lines). Then another time before this one the pedal was very very stiff. (pedal adjustment from the master cylinder. (so far so good. I got alittle more adjusting to do though)
Old Apr 3, 2003 | 08:29 PM
MaxSE98's Avatar
sweet, with everything ihave right now ill only be making 280 at 3200rpm and 340lbft at 2700 rpm, but thats stock motor with a larger manifold. once i cam it i should make quite a bit more at a higher rpm. im lookin for about 600 horse before i reach the limits of the 6 point cage, by then ill have upgraded to the corvette IRS and ill have programmable injection on. i might go insane and make some twin turbo manifolds and then throw a 1000cfm flying toilet on it or something crazy, anyways if your in CT send me a mail some time and we can chill at the pike. -pete
Old Apr 3, 2003 | 09:30 PM
Ramius83
I had my second clutch installed at a local garage. Total cost for labor was $300.00. You need to look around for a better price.
Old Apr 3, 2003 | 10:19 PM
Triocet's Avatar
$300? hmmm
i had my entire clutch system changed and upgraded to high performance for $1800 because my clutch failed.
Old Apr 3, 2003 | 10:21 PM
MaxSE98's Avatar
Originally posted by Triocet
$300? hmmm
1800???????????????? for what???????????
u dont mean your transmission do u ?
Old Apr 3, 2003 | 10:27 PM
Triocet's Avatar
no, just the clutch, i think they also did some repairs, because the clutch was fubar.
Old Apr 4, 2003 | 07:23 AM
MaxSE98's Avatar
u dont really know what cost u 1800 dollars? i could build you a car for that much ..!!!!
Old Apr 4, 2003 | 09:52 AM
Bernout's Avatar
Thanks for the replies you guys. I will definitely have the other components checked out before I go buying a clutch and all, because it DOES still grab hard... Thanks again.
Old Apr 4, 2003 | 10:31 AM
MChapel's Avatar
A year ago I had my clutch, bearings & seals replaced. Here's what I paid in Canadian Dollars: ($1CDN = $0.65US)
Remove/Replace transmission: $302.50
Clutch: $521.05
Turn Flywheel: $ 40.00
Bench Labour: $220.00
Seal Kit: $ 19.24
Balance Bearing Kit: $ 1.05
Grand Total>>>> $1,103.84 or approx. $717.50US and labour made up only about $340US of that
Old Apr 4, 2003 | 12:35 PM
NYCe MaXiMa's Avatar
bro, i got the exact same problem..
shifter is hard as f-ck to move and my clutch is very hard to depress..
it's like there is something preventing me from pushing the clutch all the way in and my tranny thinks the clutch is not depressed so i am pushing my shifter into gear with great force..
500$ for labor is too much
i am shooting for like 250-350$..
user 11122324
42
Jul 18, 2022 03:35 PM
doctorpullit
Mar 29, 2016 11:08 AM
zmcneely13
Sep 26, 2015 02:26 PM
carlosvq30
Sep 26, 2015 09:44 AM
msellas
Sep 23, 2015 09:16 PM
