Clutch slipping
Old Apr 6, 2003 | 03:16 PM
A5295's Avatar
Clutch slipping
I was drving down the highway and got on the throttle in top gear at about 80 and my clutch started slipping. Where are some places and what are some good clutches to get? I plan on doing all the work myself, so i need all the help i can get. Any tips? Does anyone have a stage two dual friction centerforce? I think i am gonna shy away from the ACT because i have heard too many stories about disentegrating transmissions with that setup. I know i can get the centerforce disc and pressure plate for about 250 plus shipping. Is there anything else i will need to replace besides the T/O bearing? Why don't i have the money for the flywheel? Thanks for the help and advice.
Mike
Old Apr 6, 2003 | 09:39 PM
A5295's Avatar
Come on guys, please help me. I need all of it i can get.
Mike
Old Apr 6, 2003 | 10:10 PM
rmb's Avatar
rmb
Maybe I'm just lucky or don't drive my car like an idiot....
But I've got over 88,000 on the original factory clutch with no signs of slippage yet. Why ask for trouble with some other brand you might not need?
Assuming you haven't tweaked much more power out of her I'd go with a factory replacement again.
Clutch + pressure plate + Throwout bearing + carefull examination of flywheel should suffice. And check the engine mounts too. One let go on me....
-RMB
Old Apr 6, 2003 | 10:14 PM
Dev's Avatar
Dev
Re: Clutch slipping
Mike
if you do'nt know which clutch to get, chances are you shouldn't do the work yourself. this is by no means an easy job. it takes a lot of time and indepth knowledge of the transmission to replace the clutch. also how are you going to resurface your flywheel by yourself?
i was under the impression that a stage 2 clutch was for racing purposes. a street application clutch would be better, or just get a factory replacement.
Old Apr 6, 2003 | 10:20 PM
rmb's Avatar
rmb
Re: Re: Clutch slipping
Yeah.... I second that, the clutch on the Max is a PITA to replace. I helped a friend with a 99SE and it royally sucked......
Midas or many autoparts stores will resurface a flywheel....
-RMB
Old Apr 6, 2003 | 10:39 PM
A5295's Avatar
The car has 120k and has never given me any trouble. It just started slipping. I have looked at and researched the cenerforce clutch setup. I want to do this on my own so that i can learn more about my car. I have a couple of mechanic friends who are willing to help me and I really don't have the cash to pay someone to do it. My budget is a little tight right now. I do plan on doing some modifications in the near future that will probably warrant the stage two setup. I thought about the OEM replacement, but I decided to go a step or two further. besides, for 250 plus shipping it is not a bad deal.
Mike
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
carlosvq30
Sep 26, 2015 09:44 AM
homewrecker
Sep 24, 2015 07:01 PM
