Installing Remote Start - where's the alarm brain??
Old Apr 7, 2003 | 05:22 PM
jacob's Avatar
Anyone? Anyone? Where does Nissan keep the stock alarm computer?
Tried searching but uhh.... Heh.
Thanks,
Jacob
Old Apr 7, 2003 | 06:09 PM
TylerBorg's Avatar
i vaguely remember somebody saying it was in the trunk somewhere on the passenger side...
this might help...
YEAR: 1996 MAKE: Nissan MODEL: Maxima STYLE:
| ITEM | WIRE COLOR |POL | WIRE LOCATION |
| 12V |wht/red - wht/pur *6 | + |ignition harness |
| STARTER |blk/yel - blk/wht *6 | + |ignition harness |
| SECOND STARTER |grn/blk - red/blu *6 | + |ignition harness |
| IGNITION |blk/wht - blk/red *6 | + |ignition harness |
| ACCESSORY |red/yel - red *6 | + |ignition harness |
| SECOND ACCESSORY |blue - wht/blu *6 | + |ignition harness |
| POWER LOCK |lt. green/red | - |in drivers door at switch |
| POWER UNLOCK |green/yellow *1 | - |in drivers door at switch |
| LOCK MOTOR |brown/white | |in drivers door at switch |
| UNLOCK MOTOR |brown | |in drivers door at switch |
| DISARM DEFEAT |brown | |in passenger door at switch |
| PARKING LIGHTS + |red/green | |steering column |
| HEADLIGHTS |gry/yel(L)blu/blk(R) | + |steering column |
| DOOR TRIGGER |red/white | - |low in drivers kick |
| TRUNK/HATCH PIN |purple/yellow | - |drivers kick or BCM *2 |
| HOOD PIN |yellow/black | - |BCM *2 |
| TRUNK/HATCH RELEASE |purple/yellow | - |low drivers kick *3 |
| FACTORY ALARM ARM |arms w/ lock | | |
| FACTORY ALARM DISARM |disarms w/ unlock | | |
| DISARM NO UNLOCK |*4 | | |
| TACHOMETER |white/green | |ECM *5 |
| BRAKE WIRE |red/green | + |at brake switch |
| HORN TRIGGER |green/white | - | |
| WIPERS |lt. green/red | - |steering column |
| LF WINDOW UP/DOWN |blu/red - blu/blk | A |in LF door at switch |
| RF WINDOW UP/DOWN |blu/red - blu/blk | A |in RF door at switch |
| LR WINDOW UP/DOWN |blu/red - blu/blk | A |in LR door at switch |
| RR WINDOW UP/DOWN |blu/red - blu/blk | A |in RR door at switch |
NOTES:
*1 Requires a double pulse.
*2 The BCM (body control module) is located just below the radio.
*3 Must use a relay to interface with this circuit.
*4 A single negative pulse to the unlock wire will disarm without
unlocking.
*5 The ECM is located in the front of the center console on the
transmission hump. The wiring is easily reached by removing the small black
panel just to the front of the center console on the passenger side. the
wire is in the middle row, 7th one in from the left.
*6 The ignition harness wires change color at a plug. The above listed
colors show both sides of the plug.
Old Apr 7, 2003 | 07:11 PM
ZuMBLe's Avatar
Re: Installing Remote Start - where's the alarm brain??
Open the jack compartment and look inside, you'll see it.
Thanks,
Jacob
Old Dec 18, 2004 | 04:05 PM
ThurzNite's Avatar
can i wire both Accessory #1 and #2 using 1 wire from the alarm?
Jae
kmitchel
Oct 28, 2015 09:46 AM
305head
Aug 26, 2015 09:03 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
maximaham
Aug 7, 2015 01:11 PM
