People with aftermarket HID - Please Read...
Where did you mount your HID ballasts? Each ballast has a mount with 2 screw holes. I was wondering if there is a way to mount the ballasts without doing any drilling. Did you guys all even use the screw holes or find another way to mount the ballasts behind the headlights under the hood?
Thanks.
Thanks.
i used zipties also but i tied it to 2 different relay boxes, one on the left and one on the right.... kinda sux if you have to actually get to the relays... but i can always cut the zipties off and put on new ones
I mounted one behind the relay box with small screws and the other underneath the fuse box next to the battery with small screws. But make sure you insulate the connections with some electrical grease so no water or corrosion get's to it.
The ballast's are out of the way and safe from damage.
litch
123
Jan 4, 2024 07:01 PM
