So how much would u spend to change the color of you clock? $10? $30? How about a $1
Old Apr 15, 2003 | 10:52 PM
Mad Dhan's Avatar
I am sort of a perfectionist when it comes to my car, and little things like the clock not matching the rest of my interior illumination really annoy me. Anyway, I decided to do something about it.
Here is just the background of my thought process. If you don’t care how this came to be u can skip to the write-up part of this post:
At first I thought the best way to go about this was to get a clock that illuminated white and just wire it up. I wanted to get a white clock because I knew from there I could change it to any color I wanted. I found that newer Lexus models had a white clock but to obtain one was no party. The ones I found were either too expensive or the wrong color. So I put this idea on the back-burner knowing that if I wanted this to happen I couldn’t rely on finding used parts.
Couple weeks went by; no new ideas came to me until two weekends ago when I was studying for midterms. Usually when I study I listen to music on my hi-fi unit. I noticed my cd player had a nice white illumination to it, so I said what the hey, lets take it apart and see if I can find anything. I did. It turns out the cd player had a different color illumination to it when I took off the cover, similar to that of the oem maxima clock. It was the cover that made it appear white on the outside. It was now obvious what I need to do; replicate the cover, and so I did. I can go on about i figured out how to produce a cover, but now i feel like playing some moto gp, so i wont.. Anyway, end result:
WRITE UP(To obtain a white clock):
1. Go to you local party store and purchase some cellophane paper. The color u are looking for is magenta or red. Now all u need is a very small quantity so buy at little as u can. Luckily it was on sale and I was able to purchase a whole role for $1.
2. Remove the clock from ur car and bring it in the house where u can easily work on it.
3. Remove the cover of the clock and remove the circuitry from the housing. Take a small piece of cellophane paper (all u need is one piece, no need to use double layers or u will get a reddish color and a blurry read out).
4. Take the small piece and attach it to the lcd using clear tape. I say tape it to the lcd and not the cover because its a little tougher to get cellophane paper to stay flush against the cover which in turn would lead to a blurry read out. Make sure the cellophane paper is tightly pressed against the lcd and space between the lcd and the cellophane paper is at a minimum.
5. Reassemble everything and ur done.
Optional:
*6. Now I know a lot of u guys were whining about not being able to have a blue clock, so if u want blue or any other color just purchase it at the party store and layer that AFTER u use the red/magenta. Note that the more layers u add the dimmer ur clock will appear to be and it might be possible that u will need to disconnect the night dimmer.
Have fun.
Old Apr 15, 2003 | 11:54 PM
Sorgasm's Avatar
Brilliant work
Old Apr 16, 2003 | 12:07 AM
kj043's Avatar
nice
Old Apr 16, 2003 | 12:18 AM
looney662's Avatar
Nice write up!
Old Apr 16, 2003 | 12:27 AM
geo1317's Avatar
sweet, i got a new project, thanks. im also going to try and do the same for the ACC, hope it works. great gob.
Old Apr 16, 2003 | 12:38 AM
Nismo's Avatar
NICEEEEEE this will be tommrows project lol
Old Apr 16, 2003 | 01:04 AM
danimsta's Avatar
SWEET
now all i need is orange paper/cellophane paper/ whatever...
hopefully it turns out ok
thanks!!!!!!
Old Apr 16, 2003 | 01:33 AM
Iilac's Avatar
Spelled with a I not a L for Iilac. Prounced Ii-eee-ack.
ooooooooooo.. good work....
Old Apr 16, 2003 | 02:47 AM
Sprint's Avatar
i changed my clock to silver
Old Apr 16, 2003 | 04:11 AM
njmaxseltd's Avatar
I don't get it?
My clock is the same color as everything else in my car?
Old Apr 16, 2003 | 06:54 AM
XXXL Cracker's Avatar
Nice clock Sprint........ looks like the Limited Edition James Bond model which was only placed in select cars....
How did you get one of those?
D
Old Apr 16, 2003 | 07:12 AM
s2cmpugh's Avatar
would this work in the ACC (auto climate control) screen, if you took it apart??
i think u really came across something here man
Old Apr 16, 2003 | 07:32 AM
abstrakt79's Avatar
SprintMax: i changed my clock to silver
showoff...haahahhahhaa
Old Apr 16, 2003 | 08:33 AM
s2cmpugh's Avatar
and also, how white is it???
Old Apr 16, 2003 | 09:51 AM
Sprint's Avatar
D
contacts
Old Apr 16, 2003 | 10:14 AM
Originally posted by SprintMax
contacts
You got the hookup...can you set up a Group Deal?
BTW, did a twin turbo come with that clock?
D
Old Apr 16, 2003 | 10:26 AM
Mad Dhan's Avatar
yes it would, just follow the same steps when u take apart ur acc
Old Apr 16, 2003 | 10:35 AM
Mad Dhan's Avatar
Originally posted by njmaxseltd
I don't get it?
That how it was stock. After i changed mu HU the only thing that was that green color was my clock. My HVAC is manual so it just illuminates white around the buttons and my guages also illuminate white.
Old Apr 16, 2003 | 11:47 AM
aznsap's Avatar
Re: So how much would u spend to change the color of you clock? $10? $30? How about a $1
hey that's a tite mod. can you notice a reddish tint at all though during the day around the numbers? also, how dim is your clock now? still very visible during the day? anybody have a writeup for how to disassemble your clock unit?
Old Apr 16, 2003 | 12:48 PM
geo1317's Avatar
just got done doing the clock, ACC and my pioneer Sirius Tunner. i picked up some pink(no red in the store) and blue paper. it came out a aqua blue, but its hard to tell durring the day ill have a batter idea tonight when i take some pictures. im sure it will look much better than before.
the clock is a little too dark, can anyone tell me which wire to cut to turn the dimmer off for the clock.
Old Apr 16, 2003 | 12:56 PM
Ramius83
I really forget the wire, but just use a multimeter to find out which one....
Old Apr 16, 2003 | 01:14 PM
max7's Avatar
WRITE UP:
Optional:
Have fun.
You have the same Alpine Radio as I do. By the way nice work!
Old Apr 16, 2003 | 01:26 PM
meccanoble's Avatar
Sports Button FTW
nice *** write up man! how do u take off the dimmer? did u ever experiment and NOT use the red magenta and just the blue?
Old Apr 16, 2003 | 04:25 PM
nadir_s's Avatar
vicodin ... gift of life
WRITE UP:
Optional:
Have fun.
you're an F-ing genious.
but green + red = purple! is the key to getting it a blue color using majenta?
Old Apr 16, 2003 | 04:45 PM
Ramius83
Re: Re: So how much would u spend to change the color of you clock? $10? $30? How about a $1
So what color would you put over the Green LEDS to get white????
Old Apr 16, 2003 | 04:48 PM
nadir_s's Avatar
Re: Re: Re: So how much would u spend to change the color of you clock? $10? $30? How about a $1
anti-green
Old Apr 16, 2003 | 04:59 PM
Ramius83
Re: Re: Re: Re: So how much would u spend to change the color of you clock? $10? $30? How about a $1
anti-green
Which is.....????
Old Apr 16, 2003 | 05:10 PM
nadir_s's Avatar
Re: Re: Re: Re: Re: So how much would u spend to change the color of you clock? $10? $30? How about
Which is.....????
it's not possible, at least w/ the cellophane idea.
Old Apr 16, 2003 | 05:26 PM
Anachronism's Avatar
Originally posted by Daniel B. Martin
The digital clock is designed to go dim when the lights are on. It is not controlled by the dashboard light dimmer. If you want the clock display to remain at high intensity when the lights are on...
1) Remove the clock. This may be done with a small flat-blade screwdriver. Insert the screwdriver blade between the lower right hand corner of the plastic dashboard clock panel and the adjacent softer dash board. Slowly pry the panel up. Continue this at all four corners of the contoured panel until the metal snaps which anchor the panel are loose. Remove the panel by pulling outward and downward.
2) Note that the clock's electrical connector has four wires. Cut the wire which is red with a blue tracer. Insulate the cut ends with a bit of electrician's tape.
3) Install the clock panel. It just snaps into place.
Old Apr 16, 2003 | 05:32 PM
InfamousOrange's Avatar
couldn't u just replace the led? wats the deal with all the cellophane?
Old Apr 16, 2003 | 05:37 PM
djshawnee's Avatar
its an LCD... it has no LED's.
also, how dim is it with only the red cellophane? how much dimmer would it get if i put the blue on it also? will i still be able to see it during the day? just white would be cool though.....
Old Apr 16, 2003 | 05:39 PM
oh d'oh i blame the heat. my bad
Old Apr 16, 2003 | 06:31 PM
geo1317's Avatar
here is the end result of the project with the result being blue. And again thank to Mad Dhan.
with lights off
with lights on and dimmer all the way up, still need to do the clock dimmer mod.
Old Apr 16, 2003 | 06:44 PM
Mad Dhan's Avatar
ok i see there is still some info that needs to be cleared up so:
-The dimmer wire needed to be cut is the red wire with the blue tracer.
-To make the clock white u need red/magenta cellophane paper. As to why this produces white as oppose to purple is beyond me. But i would think that color theory is not the same when i comes to illumination or light.
-There is no hint of red, for someone who asked.
-As for it being visable during the day, i can see it clearly. Here are some pics:
have fun
Old Apr 16, 2003 | 06:50 PM
geo1317's Avatar
thank you
Old Apr 16, 2003 | 07:05 PM
JeremiahMaximaSE's Avatar
Sweet
Nice Work Man...I've been having the same thoughts as to how to do the same thing....when I get a nice day off...I'll have a lil' project to do! Lata!
-Jeremiah
Old Apr 16, 2003 | 07:41 PM
aznsap's Avatar
nice! can somebody post real quick how to take out teh dash stuff safely w/o breaking nething? i've never pulled out that part before.
Old Apr 16, 2003 | 07:58 PM
Mad Dhan's Avatar
http://installdr.com/InstallDocs/Nissan/PDF/647021.pdf
use that as a guide. All u really need to go up to is step 3 maybe 4. You will see the screws that hold in the clock from there.
Old Apr 16, 2003 | 10:49 PM
danimsta's Avatar
well i decided to do this..
and if u havent noticed.. i am going for the orange theme, so here
ill take some farther away pics later, but this is what it looks like so far, i think it came out GREAT!!!! thanx alot Dhan...
bunch of people saying my interior is nice and orange, cept the clock, now its orange also
Old Apr 16, 2003 | 10:51 PM
danimsta's Avatar
but there is a problem...the local hobby shop only had long rolls of celaphane so i had to buy this honker.. now i have nothing to do with it?
anyone wanna buy strips of it for a dollar?????
ill provide pretty big strips?
hmm groupd deal? lol...
