Weird Problem : Help
Old Apr 16, 2003 | 11:14 AM
Kehops's Avatar
Yesterday morning, on my merry way to work, I stopped at a red light and started creeping up for the light change when all of a sudden, my car starts jerking in 1st, so I shift in 2nd but the jerking's still there. As I turned the corner at the intersection, the car just stalls and dies on me. I had just enough speed to move to the side of the road.
When I tried starting it up again, the engine would turn fine but wouldn't hook. Kind of puzzled as to what it could be since I've never experienced this problem before, I pop the hood to check things out...everything looks good, all sensors hooked up (I thought maybe it was the MAF sensor since I've forgoten to hook it up before and it was kind of the same effect) After 15 mins of cursing and such, the car finally starts up and takes off fine. The first red light I hit, I stop and wish it doesn't happen again, and of course...it does.
Got the car towed and checked by mechanic. Mechanic calls me up saying he can't do anything since he thought it was something with the fuel pump and/or filter. Both are fine. He said something about not having scanners to check sensors in a JAP car.
Seems like whenever you let the car sit for 15 mins, it starts up again only to stall once you stop and try to take off again....Very weird
Sorry about the novel, any help would be greatly appreciated...thanks
Old Apr 16, 2003 | 11:20 AM
mtrai760's Avatar
'Trynna' is not a word
You don't need an OBD scanner to pull the codes, look in the how to section of this forum and it will tell you how.
Old Apr 16, 2003 | 11:27 AM
Kehops's Avatar
I didn't realize that's what he meant.
However I already had a CEL from a few other minor issues (don't remember codes). Shouldn't cause a problem though right??
Old Apr 16, 2003 | 11:58 AM
njmaxseltd's Avatar
Wrong, the reason your CEL light is on is because something needs to be fixed.
Pull the codes and fix whats wrong and your car will run correctly.
http://forums.maxima.org/showthread.php?threadid=104931
Good luck!
Old Apr 16, 2003 | 12:06 PM
MacGyver265's Avatar
Good luck!
Just so you know, not all OBDII codes can be retrieved with the "check CEL" procedure we all know. ODBII will let out more codes with a scanner. Go to Autozone, they will give you a printout of all the codes your OBDII outputs and what they mean for free.
Your symptoms sound something like a bad TPS (throttle position sensor)
Old Apr 16, 2003 | 12:10 PM
Kehops's Avatar
Good luck!
That's not what I meant but doesn't matter, the codes I pulled before is just something that appeared after I installed my custom air filter.
Many people on here run with CEL on with no problems what so ever.
JF
Old Apr 16, 2003 | 12:14 PM
Kehops's Avatar
Could be that...
The only place around here with an OBDII scanner is Candian Tire and they charge 40$ to pull them.
Old Apr 16, 2003 | 12:36 PM
iansw's Avatar
Those people usually know what the CEL means, however, and why it's there....
You don't seem to know either of those things.
IanS
Old Apr 16, 2003 | 12:46 PM
Kehops's Avatar
IanS
Au contraire mon frere. As I stated earlier, I've pulled the code and looked it up...it was so long ago I don't remember the EXACT code. You obviously took the time to write this reply so I can take the time and go pull it again if it means that much to you.
Thanks for your input though
05RLS2
Sep 27, 2015 09:24 PM
homewrecker
Sep 24, 2015 07:01 PM
yamehoo
Sep 24, 2015 10:21 AM
bennuss
Sep 11, 2015 05:55 AM
