How do you remove the side view mirror?
I'm assuming that to remove it I would have to remove the inside door panal and get at the screws and wires holding it up? But if I were to remove the inside door panal, would there be a chance of ripping apart of wire connection or something? This is regarding the driver side mirror. Hope you guys could help, thanks.
P.S: Links or the sort would be helpful too.
Maxima 99' SE-L
Maxima 99' SE-L
Re: How do you remove the side view mirror?
[QUOTE]Originally posted by hito
Maxima 99' SE-L [/QUOTE
You will need to remove the panel. It's not that bad. You will probaby break the little plastic dish aroung the handle since it's a b1tch to get out(less than $10.00 I think). But there are no wires connected to the panel. A few bolts hold the mirror in place and a molded connector unplugs the mirror wiring harness.
No biggie....
-RMB
No biggie....
-RMB
Thanks. Sounds simple enough. It also looks that there may be two wires however... One for the door clearance light, and another for the window/door lock switches. Also, the bolts are underneath that triangular plastic covering i'm assuming? Thanks for helping me with this, I appreciate it.
![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
The Frye
09-02-2021 11:03 AM
03-12-2020 12:06 AM
flu2000
09-08-2015 02:23 PM
