Headlight wireharness burned
is there a reason why my wire harness keeps burning out when i put one of those HID bulbs in??? u know the ones that replaces the stock bulbs.
is there a way to fix this??? do i have to replace the entire wireharness to the headlights to prevent this from happening??? someone help...
Unfortunantly a lot of people have bad luck with high power aftermarket bulbs and them frying up the headlight harness. In order to upgrade to those type of bulbs you will have to upgrade your headlight harness, I'm not sure how much it costs though but ask around. Good Luck, Take Care.
Re: Headlight wireharness burned
Dude... you can get the harness on Ebay. Type "9004 Harness" in the search. Runs for around $12 for the pair. Thats what I got. Works awesome now. You dont need the whole harness kit with the relays and all that stuff. The stock relays are more than adequate for an 80/100 watt bulb setup. Just remember, when installing the harness, in most cases the wiring color does not match. Just match the wiring poeitions on the harness and you will be fine.
i put one of those wannabe HIDs
cant afford the high price of HID conversion kits unless you guys know where i can get it for under 300 ... or a fellow org member who are selling them for that price
http://cgi.ebay.com/ebaymotors/ws/eB...category=36476
Check those links.
Or try this brand, I had it for two months and no problems yet.
Any other suggestions???
You have 3 choices:
1. Get a full HID conversion.
2. Get a new wire harness so you can run higher-wattage bulbs.
3. Get brighter stock-wattage bulbs (Like silverstars, bluevisions, etc.) But, still replace your harness, because it's useless now.
doctorpullit
Oct 28, 2019 10:58 PM
