5spd Conversion - axle question #2
Old Apr 21, 2003 | 10:05 AM
  #41
johnvt1111's Avatar
Re: Re: Re: Re: Re: 5spd Conversion - axle question #2
Originally posted by Ramius83
The internals are the same, but the mounting holes and casing are totally different from ours....
do they make 2000 lsd manual trannies?
Old Apr 21, 2003 | 11:58 AM
  #42
Scruit's Avatar
U wanna try me young boy?
OMG... S/C, MEVI, 5spd... *DROOL*
Old Apr 21, 2003 | 12:07 PM
  #43
iansw's Avatar
Soon to be:
SC with a 3.125" Pulley
MEVI
SAFC
5spd
AND
JWT ECU!
Maybe soon SprintMax won't call my car slow anymore.
<j/k>
Old Apr 21, 2003 | 12:26 PM
  #44
aznsap's Avatar
Originally posted by iansw
Soon to be:
MEVI
SAFC
5spd
AND
JWT ECU!
<j/k>
daaaang... btw, are u gettin an aftermarket clutch?
Old Apr 21, 2003 | 12:28 PM
  #45
iansw's Avatar
Yep - ACT installed.
Forgot to mention - got that with T/O Bearing for $300 shipped.
So total cost is really $900
Old Apr 21, 2003 | 01:02 PM
  #46
aznsap's Avatar
stock flywheel then? what's the benefit of using the fidanza flywheel as opposed to stock? about the locking pin and bolts and such on hlh's site, instead of purchasing from nissan, couldn't you jus pull those from the donor vehicle? i hope to eventually become one of the auto to 5-speed converters, so im jus doin my research, anyway, im happy for you iansw.
Old Apr 21, 2003 | 01:16 PM
  #47
iansw's Avatar
I don't know the exact improvements with the Fidnza...maybe someone else can answer that.
The things that hlh mentions as "buy from the dealer" are usually there for a reaosn (Like the return spring, because you want it to be brand new)
Old Apr 21, 2003 | 03:28 PM
  #48
johnvt1111's Avatar
What's a SAFC?
Old Apr 21, 2003 | 03:31 PM
  #49
iansw's Avatar
Originally posted by johnvt1111
What's a SAFC?
Apexi Super Air Flow Converter:
Old Apr 21, 2003 | 04:07 PM
  #50
johnvt1111's Avatar
why do you need that for a 5 spd conversion, or is that for your s/c
Old Apr 21, 2003 | 04:09 PM
  #51
iansw's Avatar
To tune the Air/Fuel ratio for the SC and even low-end, before boosting.
The Cartech Adjustable FMU I have is tuned pretty well, but the AFC should allow me to "even out" the fuel curve even moreso.
(I haven't gotten around to tuning it yet)
Old Apr 21, 2003 | 05:20 PM
  #52
aznsap's Avatar
hey do your reverse lights come on when you put it into reverse? i don't know if hlh's how-to included that. also, i know for the spring i should by new, but for the bolts and nuts...... can't i jus acquire those from the donor car?
Old Apr 21, 2003 | 05:27 PM
  #53
johnvt1111's Avatar
can't you get bolts and nuts really cheap????????
Old Apr 21, 2003 | 06:03 PM
  #54
aznsap's Avatar
yes, but how would you know you're getting the right parts? i was looking at hlh's site and it says the dealer has to find the parts for you, not tooooo specific.
Old Apr 21, 2003 | 08:12 PM
  #55
iansw's Avatar
OK - new problem.....2 actually
I can't find the "banjo" fitting for the slave cylinder....I've looked everywhere - it appears it was never shipped, but I can't be sure.
So we're done except for that. Nissan says it will take 3-4 days to get, but NAPA says they can have one tomorrow....hopefully they will, but I have to work 7am-7pm for the next 2 days...sucks...
The other problem is this:
It will shift into 1st, 2nd, 4th, 5th, and R just fine, but NOT 3rd!!!
stick doesn't even budge a little bit into that gear....just hits a solid wall.
Now, the car hasn't been started or moved, but this concerns me....any ideas/statements?
Old Apr 21, 2003 | 08:27 PM
  #56
Ramius83
So, is the tranny actually in the car now, and you have installed the shifter? If it won't go into third, then you may have a problem. Check underneath the car and have someone try to shift it into third. It may be that the shifter rod is colliding/rubbing the support rod and not allowing it to push the tranny into third. I know that this was my problem. I corrected this be spacing the support bar out away from the tranny with washers.....
Old Apr 21, 2003 | 08:31 PM
  #57
iansw's Avatar
You had the exact same problem with 3rd gear, but no other gear?
Every other gear shifts amazingly smoothly.
Old Apr 21, 2003 | 08:48 PM
  #58
Ramius83
Ian, is the tranny actually in the car now? Or are you ghetto rigging it to see if the rod shifts?
Old Apr 21, 2003 | 08:50 PM
  #59
iansw's Avatar
In the car....
Everything is done except for that hydraulic fitting I'm waiting for.
Old Apr 21, 2003 | 09:02 PM
  #60
Ramius83
In the car....
Ok, so did you check to see if the two rods are rubbing together....
Old Apr 21, 2003 | 09:19 PM
  #61
mtrai760's Avatar
'Trynna' is not a word
I installed the rods and got under there while I had someone move the shifter around, and I didn't see/hear anything hitting together. Guess we'll just have to take a look.
Old Apr 21, 2003 | 09:21 PM
  #62
iansw's Avatar
I'm not anywhere near my car...I don't have my own garage, so I'm borrowing a friend's uptown...
mtrai760 installed the rods, and says he didn't see any rubbing....
So did you only lose 3rd or not?
Anyway, I'll check it out when I get up there again in 2-3 days (have to work 12 hour days for the next 2 days)
Thanks!
IanS
  #63
maximase86's Avatar
I love lamp.
mtrai760 put the shift rods in, and they seem to be fine. We should probably double check it to see when someone is shifting through the gears. It was shifting into 3rd/4th fine before it went into the car. I think it will be fine once we get the car running and moving a little bit. It will allow the tranny to spin a little bit and get the synchros lined up.
On that note....banjo fittings/bolts bite my a$$. Can't believe such a small thing can hold everything up....
S
Old Apr 21, 2003 | 09:24 PM
  #64
iansw's Avatar
S
No doubt....banjo bolts suck.
May as well post "props" here:
mtrai760 - project lead
maximase86
schuss
ebmorgan
mrb23
Thanks to all of you....and anyone else I forgot.
Old Apr 22, 2003 | 04:20 PM
  #65
iansw's Avatar
Ramius - was it the tranny end or the shifter end of th control rods that was blocking your 3rd gear?
And again, was it only 3rd gear?
Going to look at it shortly.
Thanks,
IanS
Old Apr 22, 2003 | 06:05 PM
  #66
Ramius83
Ian, It rubbed where the two rods "bend" near the rod of the transmission. When we shifted ONLY into fourth, they would rub together and not allow us to shift into 3rd. But, this was my problem and may not necessarily be your problem....
Old Apr 22, 2003 | 06:16 PM
  #67
iansw's Avatar
Sounds good - I think it may be my problem, as it shifted into 3rd (3rd is straight back on the mechanism, correct?) when we had it out of the car.
Thanks,
IanS
Old Apr 22, 2003 | 08:27 PM
  #68
iansw's Avatar
Well, we checked the rods, and they don't rub whatsoever...
Still, trying to shift into 3rd is like hitting a brick wall.
I think the tranny is screwed, personally, but others tell me I just need to get it started, and let everything sync up.
Unfortunately, I can't do that right now because I ordered the banjo fitting from NAPA, and they of course got the wrong one. No clutch, no move....
Anyone have any ideas/suggesstions/analysis?
Old Apr 22, 2003 | 08:38 PM
  #69
mtrai760's Avatar
Ian, I never saw your tranny shift into third before we installed it, and I thought Sarin said it still wouldn't shift into 3rd when he put it back together. Sarin got it to shift when everything was apart I think, but I'm not positive. 3rd is straight in, not out, out is 4th.
Thanks,
IanS
Old Apr 22, 2003 | 08:48 PM
  #70
iansw's Avatar
Sounds like you think as I do...bad tranny.
EB says that you guys had a really hard time in every gear, until it loosened up after awhile...that true?
(No, 3rd is straight back (all the way extended) on the mechanism on the tranny itself, I meant, of course is straight forward on the stick)
Old Apr 22, 2003 | 09:09 PM
  #71
Nismo's Avatar
hope it isnt this thats causing it http://forums.maxima.org/showthread....hreadid=209196
Old Apr 22, 2003 | 09:10 PM
  #72
iansw's Avatar
Nah - we had it apart...the rod was perfectly straight.
Old Apr 23, 2003 | 08:37 AM
  #73
mtrai760's Avatar
Hmm, don't know what EB is talking about, sure it was hard to get in every gear, but the car also is not running, so of course its hard to get in gear, I dont know anything about it getting easier though... I don't know, I guess just get the car running and pray...
Old Apr 23, 2003 | 08:40 AM
  #74
iansw's Avatar
Oh - he was saying that 5th and R were as impossible to get into gear at first as 3rd is now, until they shook it around a bit....and 4th was almost that hard.
No biggie....he tends to exaggerate pretty much everything.
Old Apr 23, 2003 | 08:45 AM
  #75
mtrai760's Avatar
No, they were all confused at first, they thought the shifter was screwed up and at an angle, and thought it would only go into 1,2,3 and 4th, but they were skipping right by 4th and reverse. Eb thought 5th was 3rd...
Old Apr 23, 2003 | 08:51 AM
  #76
iansw's Avatar
man..that guy BS'es about the most pointless stuff to BS about...
Anyway...this sucks....I'll find out tomorrow morning after we get that fitting in whether or not starting/moving it will help.
IanS
Old Apr 23, 2003 | 12:55 PM
  #77
iansw's Avatar
Well, I have afriend picking up the hydraulic fitting from the Dealership right now...
I called several tranny shops today. All of them said that i shouldn't even start the car, because if something is loose in there, it can cause major problems.
However, when we had the tranny apart, there was nothing floating around in there (although there is a 2nd stay bearing that we looked for for 45 minutes and couldn't find)
It oculd be they just odn't want me to start it because they don't want me to get it working and want to charge me to look at it.
decisions, decisions.....
Old Apr 23, 2003 | 01:45 PM
  #78
skeelo34's Avatar
try cranking the engine instead of starting it with the wheels in the air. i remember i couldnt really get into gears after the conversion until the car was on.
Old Apr 23, 2003 | 01:46 PM
  #79
iansw's Avatar
yep- wheels are on the ground...
Well, I guess I'll just give it a shot tomorrow morning.
IanS
Old Apr 23, 2003 | 04:05 PM
  #80
BippuBenji's Avatar
I think there was a list somewhere - but search is gone for alot of people.
I ended up getting non-LSD, because I got a great deal on everything ($600 for all conversion parts).
Yesterday I went to the Nissan Dealer and verified - the passenger side axle is the same for both 5spd and manual...ABS or not. SO you only need a Driver's side axle.
IanS
Ok new question. If I currently have ABS, and I need a driverside axle, is there a difference in a non-lsd and lsd driverside axle? I'm pretty sure there is a difference in ABS or not, but what about the lsd?
-Ben
