High pitched noise that varies with speed, very concerned
Old Apr 19, 2003 | 12:56 PM
bb0ys's Avatar
Today I was driving with the windows open (beautiful out in NY) and I noticed a very high pitched squeel from the front of the car, no where specific though. It varied ONLY with speed, not RPMS. The noise was the same with brakes applied or not, and i couldn't hear it at idle. This makes me want to eliminate frozen caliper and belts, but maybe I shouldn't eliminate them. Any suggestions? I can't really "look or listen" to a specific area when my car is in motion, and this is the only time it makes noise.
Old Apr 19, 2003 | 12:59 PM
wordjb's Avatar
I had the same problem but I could hear mine at idle, it was the loudest at idle. I figured out that it was the idler pulley, the bearings went bad. Replaced that and the noise was gone. But thats off topic, yours sounds like it could be a belt, but you should check the voltage of your alternator. Good Luck man!
Old Apr 19, 2003 | 01:04 PM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
Re: High pitched noise that varies with speed, very concerned
HOw much miles you have on your max, it is very possible that is your drive belts. open the hood, and go to the left of engine. and put your ear close to the water tank for washer. see if you hear the noise from there. there are two belts that need to be replaced. your belts gets dry and they start making noise. i have that on my car. so i went to mechanic close to my house. he told me they dryed up but there is no crack on them. i should save my money. i was happy.
Just check it out.
Old Apr 19, 2003 | 02:04 PM
plurco's Avatar
5 speed if so that is exactly how the diff bearing in my tranny sounded when they were going bad.
Old Apr 19, 2003 | 04:09 PM
bb0ys's Avatar
I don't think its the belts because I can't hear it at idle (with hood open) and the sound doesn't change with the RPMs. It only changes as I speed up and slow down. I REALLY hope it has nothing to do with the transmission, i just bought this car 2 months ago, could it be the wheel bearings? anything but the tranny!
Old Apr 19, 2003 | 04:21 PM
CystumMax's Avatar
It could be that it is not comming from your engine, it could be that it is comming from under your car. it could your CV joints. or something like that. try to get under the car see if anything is broken or you see any grease around the wheel. usally CV joints when they dry out they make noise like that.
But I could be wrong.
plurco's Avatar
if it stopes when you push in the clutch while rolling then it is the tranny.
Old Apr 19, 2003 | 04:26 PM
bb0ys's Avatar
didnt think of that
I didn't think of testing it like that. Wow im sort of scared to find out if it REALLY is the tranny....oh boy...I'll check the CV joints too, but i dont hear any clicking on turns so im reluctant to think its them.
*please dont be transmission*
Old Apr 22, 2003 | 02:48 PM
bb0ys's Avatar
Noise gone?!
I was going to see if I could diagnose the noise better, but it's gone! I drove the car around town, and then 200 miles to boston and it never came back...oh well. im going to change the 5sp fluid just incase
Old May 5, 2003 | 06:44 AM
nsignore's Avatar
Re: Noise gone?!
Am I the only one who thinks its the bearings? I have the exact same problem and am thinking whether we need our bearings repacked/greased. Mine varies w/ speed and sounds very "external" to the engine. The sound is projected out the sides, I hear is most prominently when I'm driving near a wall or guardrail.
How much does it cost to get bearings redone (not replaced)?
Mar 12, 2020 12:06 AM
240tomax
Sep 13, 2015 03:28 PM
ballerchris510
Sep 11, 2015 05:29 PM
jfl330
Sep 4, 2015 01:44 PM
Justin Kroll
Sep 2, 2015 11:06 AM
