ne1 know how to remove any of the front fule injectors?
Old Apr 19, 2003 | 05:14 PM
tryme's Avatar
one of my injectors are bad. i am looking to see how to remove it. i have the top screw and cover off. now i see the injector. i assume i have to take the fuel rail off. not sure how. any ideas?
plus how does the injector come out?
Old Apr 19, 2003 | 05:26 PM
95CustomMaxima's Avatar
To remove the injector, you take a pliers and grab around the square part of the injector. Then you twist and pull and it will come out. You do NOT need to remove the rail to get the injector out. Make sure when you put the new injector in that you lubricate the O-rings with some motor oil.
-Nick
Old Apr 19, 2003 | 05:34 PM
tryme's Avatar
how hard do i have to pull?
how hard should i pull? i can rotate it in both directions but not past the intake manifold. am i understanding you correctly?
-Nick
Old Apr 19, 2003 | 05:38 PM
Re: how hard do i have to pull?
You might have to give it a good pull..pretty hard..it will come out, just make sure the pliers is gripping it tightly and just start twisting/wiggling it when you pull.
-Nick
Old Apr 19, 2003 | 05:42 PM
tryme's Avatar
is there a way i can test to see if it is bad?
is tehre a test i can do to test to see if the injector is bad?
-Nick
Old Apr 19, 2003 | 05:46 PM
Re: is there a way i can test to see if it is bad?
Did you get the injector out? Also why do you assume the injector is bad? Was your engine light on? If so, did you check the computer for codes to see if there is a cylinder misfire?
-Nick
Old Apr 19, 2003 | 05:49 PM
tryme's Avatar
here is what i did
the car is missing a little. i pulled the connector to the coil and the engine sounds the same. i switched coils and spark plugs with cylinder next to it. smae problem same cylinder. i am getting a spark and i can tell i am cause the plug is dry. so it looks like a fuel problem. i have compression. so either the injector is bad or the wire to the injector is bad. any way to test either one? i don;t have the injector out yet. i will in a min or so
Old Apr 19, 2003 | 05:58 PM
I do not know of any ways to test the injector... DO you by any chance have a new injector? If so, then pull out the old replace it with the new and then see how the car runs.
-Nick
Old Apr 19, 2003 | 06:00 PM
tryme's Avatar
so you are sure all i have to do is pull on the injector?
how does it get fuel then? i just don;t wnat to break it
-Nick
Old Apr 19, 2003 | 06:05 PM
Re: so you are sure all i have to do is pull on the injector?
Im sure you should just pull on it.
Old Apr 19, 2003 | 07:09 PM
Confused's Avatar
Permanent Maxima.org Resident
if you have a panel popper you can stick it in one of the slots on top of the injector and leverage it against something. it takes some force.. you probably scared of breaking it so start slow and add more pressure.. eventually it will just pop out and splash some fuel on your face (keep you mouth closed and glasses on)
oh.. make sure your new injectors has o rings on it and the prindle (white end cap with four claws over the bottom) is good.
Matt93SE
May 24, 2019 02:58 PM
Finkle
Sep 27, 2015 09:53 PM
raffivegas
Aug 23, 2015 09:54 PM
Balkins
Aug 12, 2015 06:39 AM
kirkhilles
Aug 8, 2015 10:53 AM
