Slack in my Steering wheel
Old Apr 20, 2003 | 05:48 PM
FormorAccordMan's Avatar
So, I'm on the road and get the car up to about 85ish on a nice straightaway on I95, and notice that my steering wheel seems to be tracking every damn imperfection of the road, wiggling to every groove on the pavement with about 1/2 an inch of slack when sitting dead center. Definately not a feeling of beeing planted on the pavement, (anything below 70mph and the steering felt more precise-with less slack)I really cant remember if the car has done this-. I bought the car about two months ago and this was the first time I got to really let her out. Is this the way the max is supposed to be? Can it be adjusted? The car tracks perfectly straight, the wheel just turns to jello at high speeds when going straight. 99SEL 38k. Any thoughts?
Old Apr 20, 2003 | 09:23 PM
rmb's Avatar
rmb
Re: Slack in my Steering wheel
Things to check and get checked:
1)Cold Tire Pressure - post results
2)Alignment - post results - Could be just screwed up or too much camber one way or the other.
3)What type/size tire? - post results
4)Lowered? What springs/shocks?
-RMB
Old Apr 20, 2003 | 11:08 PM
Yossarian's Avatar
Try Energy Suspension Polyurethane Endlinks for your front sway bar. Do a search for the part # and buy them from http://www.suspension.com/s.b.bushings.htm
This seemed to fix the problem of steering slack on my car, probably due to the badly worn rubber bushings I'd removed (65,000mi).
Old Apr 21, 2003 | 04:59 AM
Lime's Avatar
yeaaahhhh, or maybe you ought to get your power steering pump checked, and your steering rack. Apparently mine had some kind of gap that was causing loose steering. All fixed up now.
Old Apr 21, 2003 | 06:49 AM
i just had a wheel alignment done on the car this passed week. maybe I ought to go back to the shop that did it. Something must be loose I guess. It never ends. There is always something to do with this car.
Tire pressure cold- 32/29 like Nissan reccomends.
The car is Completely stock, 5 spoke SE rims, with Continental CH95 tires.
What is it that they can mess up in the alignment that would couse the loose steering? So this way when I go back I can suggest shat to check for. Thanks
Old Apr 21, 2003 | 07:37 AM
njmaxseltd's Avatar
Continential tires, had them on the 330 and couldn't wait to get rid of them. We popped two because of NYC roads and soft sidewalls. They don't get good reviews on TireRack either.
RATINGS:
Would buy again - they score a 6
Overall satisfaction - they score a 7
Best tire in that catagory is like a 9.xxx
So your tire is an average Joe and could be the reason your Max doesn't track that well at high speeds.
Old Apr 21, 2003 | 07:54 AM
rmb's Avatar
rmb
A bad alignment can cause exactly what you're seeing. Too much positive camber can do strange things like darty steering / poor cornering etc... Too much negative will wear the **** out of your tires and follow every rut. They might have also not tightened something down... it happens...
Those tires also suck.
-RMB
JoshG
51
Sep 21, 2015 10:41 PM
Bonka
Sep 14, 2015 11:18 PM
2kmaximel
Sep 10, 2015 08:13 AM
SusieQQ
Sep 9, 2015 12:14 PM
coasterswim
Sep 2, 2015 07:43 AM
