EVAP problems with my maxima
I pulled a code from the ECU. The code was 10 08 (EVAP Canister Purge Volume Control Valve... I try to replace the part, only to find out that one bolt was stripped in the EVAP Canister... I got a new EVAP Canister.... I get home and put on the new Canister and Valve. THen I reset the ECU.. When I start up the car, it wanted to cut off, and its idling at around 500 RPM..... I took it to have the emission test done, and it fails. THe codes they come up with are "Vent Control Circut Malfunction(P0446), and Purge Flow Sensor Circut High Input (P1445)
Any suggestions???? Thanks in Advance..
Make sure the purge control valve is plugged in properly. I remember when I did mine, it took a fair amount of pressure till the harness clipped in correctly (thought it was in but a friend noticed it was not).
Lakersallday24
Nov 7, 2024 07:31 PM
