CAI Install Help
Old Jan 20, 2001 | 10:59 AM
jdholman's Avatar
I just bought a CAI from Cattman for my '99 SE. It comes with a few pieces of paper the manufacturer (Place Racing) refers to as an "Installation Guide" if you can call it that. In a word...It stinks!
I am trying to figure out where the paper template is supposed to go so that I can cut through the wheel well. It is supposed to line up over the battery holder mounting holes, but I can seem to get it situated to where I would be confident enough to cut my beloved SE.
Any help would be appreciated.
Regards,
Jim
Old Jan 20, 2001 | 12:12 PM
nismo96max
As far as I remember from my install, you have to remove the battery holder and line up the template with the holes.
Adam
Old Jan 20, 2001 | 12:51 PM
1MAX2NV's Avatar
You have to remove the battery tray->
the template then can line up againest some of those holes that holds the battery tray.
Regards,
Jim
jdholman's Avatar
Adam
I was able to start cutting the hole, but as I am using a small jigsaw with a metal cutting blade, I can only get so far before I run out of room to use the saw. The jigsaw isn't very good in small spaces.
What else could I use to finish the cut?
Once that is done, how can I access the space beneath so that I can mount the air filter element?
Thanks,
Jim
Old Jan 20, 2001 | 01:27 PM
jdholman's Avatar
Doug,
Do you mean those round saw attachments to a standard drill?
Also, what's Tony's email address? His install looks good.
Thanks,
Jim
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
2kmaximel
Sep 16, 2015 03:19 PM
A32goldylocks
Sep 16, 2015 01:33 PM
Johnny9595
Sep 3, 2015 05:18 AM
