bad news from mechanics
Old Apr 23, 2003 | 08:00 AM
s0ber's Avatar
Well some of you know of my unfortunate troubles that im having with a knocking sound coming from my engine... I took it in for a rough estimate and I got some pretty interesting news.....
They are not clearly sure what the problem is either the waterpump or the timing chain... sadly there labor is a big pain in the butt... Heres the parts list I need some maxima expert advice... I rather get a new engine for the price of this...
- Timing Chain, Includes: R&R Front Timing Cover
- Timing Chain Guide
- Tension Side/Upper/Center/Lower
- Timing Chain Tensioner
- Camshaft/Right
- Water Pump
Labor: $649
Parts Cost: $287
What do you guys think??? Im going to try a mechanic friend of mine who probably wont charge me as much labor... Sucks to be meeeee my friends...
EDIT: Sorry about the repost, I really meant to post in the 4th.
http://forums.maxima.org/showthread.php?threadid=209127
Old Apr 23, 2003 | 08:01 AM
njmaxseltd's Avatar
Re: bad news from mechanics
I don't like that line.
Don't have all that work done only for the knock to still be there...
Old Apr 23, 2003 | 08:08 AM
Street Reeper's Avatar
Handsome
Get a second third and even fourth opinion if you can, hope everything goes well.
Old Apr 23, 2003 | 08:21 AM
sandman1098's Avatar
Good Luck in finding the problem.
Old Apr 23, 2003 | 08:52 AM
95maxmadman's Avatar
Yeah, good luck.
Maybe you could get the parts and do it yourself???
Is it a DIY job?
How much do you think it'd be to get a new engine installed?
Old Apr 23, 2003 | 09:14 AM
G1Max's Avatar
Originally posted by 95maxmadman
Yeah, good luck.
Is it a DIY job?
It is definately not a DIY job. For the kid who has the knock, you could have already done extensive damage to the inside of the engine, so you might want to consider a new motor. When I blew my motor I bought a used for $500 with 60k on it, came with a one year parts and labor warranty, even came with a new clutch too off of a totaled 97 Max, If you would ever consider doing it there is also a vin tag on the motor as well where you can do a carfax check on it as well. The whole job cost me $1100 bucks. Car runs great. just a suggestion
Old Apr 23, 2003 | 09:59 AM
Dreizehn's Avatar
Prices I got quoted to me from Courtesy Nissan...
The prices are as follows:
Main chain: $60.11
Cam chains: $42.32 each
Tensioners for cam chains: $57.48 each
Main guides: $10.31
$23.93
$57.48
Main tensioner:
$57.48
Large guide bolt: $1.89
He told you need a new front and rear case also? I don't see why. Unless he messes yours up taking it apart.
Old Apr 23, 2003 | 11:25 AM
Dave B's Avatar
Not DAVEB the parts guy
Is this what Nissan said your car needed or was this some independent shop. For some repairs, Nissan techs aren't needed, but for something like this you need Nissan. If you're worried about the motor, simply check the compression and then check the vacuum. Those two things will tell you A LOT about the motor. Getting a new motor sounds easy and all, but remember how much you'll spend on install also. $800-1000 for a motor, $1000 for install.
Dave
Old Apr 23, 2003 | 11:34 AM
G1Max's Avatar
It took only 12 hours to swap the motor. That should equal $700 for labor, paid $512 for my motor (60k) with 1 year parts and labor warranty, (ABC/Greenleaf Used Auto, Leominster Ma.) A new or reman motor goes for about $4,000-$5,000
Dave
Old Apr 23, 2003 | 12:25 PM
bgod's Avatar
loose timing chains or bad waterpumps do not necessarily cause knock.
there area number of factors that can cause knock. compression tests and vacuum measurements will only tell so much. usually the only way to truly find out is tearing apart the motor.
if your motor is truly knocking it won't stop by just changing the chain and waterpump.
now, if there's a rattle coming from the chain or a scratching sound, that's a different story.
however, sounds like it could be time for a used motor.
Old Apr 23, 2003 | 01:04 PM
s0ber's Avatar
ok, I wish a had a mic or something to record the sound... Its similar to what you described... Its a knock but you also hear metal scratching or something like that like you said.. its knock knock scratch knock knock knock scratch.. similar to that effect...
Old Apr 23, 2003 | 01:06 PM
Dreizehn's Avatar
Is there a wicca wicca in there somewhere?
DJLAX152
May 4, 2021 11:46 AM
Mar 12, 2020 12:06 AM
spencerwh1
Jun 30, 2016 05:44 AM
The Wizard
24
Oct 1, 2015 08:47 PM
msellas
Sep 23, 2015 09:16 PM
